  • 0
Fitting a stand alone Volt meter to my Lithium batteries
Question
I am considering fitting a direct reading low cost digital volt meter to my 2 unit lithium battery bank. This is mainly for convenience, to quickly check their voltage state as compared to what the inverter is reporting.  Is their a best practice solution for this idea?  Should I fuse the positive line to the digital meter and if so what size fuse, thinking of using 1.25 amp fast fuse.
1 answer to this question
  • 0
I have done this.. The Volt meter came from Communica and the combo meters came from ACDC.
I cant speak on fuses for the meters. All me meters are installed on the "outside" of the meters & breakers, so it did not occur to me to install dedicated fuses for the meters but I would be interested to hear other's opinions on this.
Answer this question...
