Axpert :Mains not showing or charging batteries
Mains sign not showing on inverter since yesterday? Any idea why?
Last night batteries cut out and did not go to using eskom. Not sure how to load pics.
Can think of only 2 reasons:
  1. No mains - (circuit breaker tripped, power failure).  Can you check with a multi-meter that there is 230V on the input to the inverter?
  2. Inverter faulty.
1. Check if you dont have a tripped breaker in the DB.
2. Check the breaker at the bottom of the inverter.
3. Check if you have AC at the inverter using a multimeter.
If all these are in place then maybe try a hard reset. If this does not help then your inverter is faulty.
