isetech Posted September 15, 2020 Share Posted September 15, 2020 I have a 5 kva genrator ... a meccer inverter etc etc ... made a plan to get things to work. But now at a point where i need to come up with a cheap solution for light during load shedding. I have 3 magneto LED lanterns (bought from game for R199 on special a couple years ago) positioned in the bedroom ... passage and kitchen. They generate a lot more light than i expected ...for the price and the duration they last on battery power ... i am super impressed. We even use them on site for lighting in roof spaces etc ... I could run power points to each light and leave the switch on standby mode (that would require an electrician @ R650 per plug point chased into the wall) When the load shedding started again it got me thinking ... a cheap solution for load ... I thought of a small inverter or UPS connected to a battery using 230 volt downlights ... because i couldnt find a pure sine wave unit in my workshop ... I tried a modified/ square sine wave unit ... too much flicker ( iam sure someone will recomend a pcb to reduce the flicker) I came up with what i think is a cheap solutions with no losses going from 12 vdc to 230 vac via an inverter A 5 amp charger ... 18 amp/hr battery (regal sell the box complete) ... 5 m strip of 12 volt DC strip light (cool white) ... a hand full of DC connectors and some 0.5 mm twin flex. I recently replaced a few faulty linear LED lights ...so i am gonna remove the fault leds and controls and replace with 12 VDC strip. Battery = 18 amp/hr gel (216 w/hr) voltage = 12 VDC lights = 4.8 watt/m (using half a meter) 2.4 w per light Duration required = 4 hrs An exo 7 receiver with 7 relays ... one on board and the other 6 extenernal (rather than addition switches) because it requires 12 VDC ... the 4 buttons can be configued to switch all 7 relays 5 metre strip s of 0.5 mm ripcord with DC plugs ...for ease of installations (long enough to reach all the rooms in the house ... i could make a few shorter) All this for around R 12-1500. calculations: 216 w/hr /2 = 108 w/hr (50 % discharge) 10 lights @ 2.4 w = 24 watt 24watt * 4 hrs = 96 w/hr required Am i on the right track ... any advise or input would be apprieciated. Next to add a small solar panel small enought that doesnt rqeuire a charge controller ... as the budget allows. There are solar panels and fancy inverters etc in te pipeline ... but for now ...i need to keep things simple. Quote Link to comment Share on other sites More sharing options...
ChristoSnake Posted September 16, 2020 Share Posted September 16, 2020 I did this before going the full PV/inverter route, and left it in place as a backup. My system is powered by a sealed alarm battery that is permanently charged with an adjustable power supply set to 13.6V. I used caravan lights in the bedrooms and trimmed LED strips to suitable length & mounted them against the living rooms & bathrooms ceilings. These battery operated wireless switches use an inline relay (powered by the same 12V feed) to turn them on & off. I mounted the backup system's switches next to 220V light switches. There's plenty of light available, and by adjusting your battery size as required you'll be fine. Quote Link to comment Share on other sites More sharing options...
Arandoza Posted September 16, 2020 Share Posted September 16, 2020 Folks are also taking the easy option and plugging in these types of globes with battery backup. Not sure how well they work though? https://www.google.co.za/search?source=hp&ei=GiFiX8fRFaO3gwft6bL4CQ&q=light+bulbs+with+backup+battery&oq=light+bulbs+with+back&gs_lcp=CgZwc3ktYWIQARgAMgIIADIGCAAQFhAeMgYIABAWEB4yBggAEBYQHjIGCAAQFhAeMggIABAWEAoQHjIGCAAQFhAeMgYIABAWEB4yBggAEBYQHjIGCAAQFhAeOggIABCxAxCDAToFCAAQsQNQwzVY8V5g9XhoAHAAeACAAecCiAHEK5IBBjItMjAuMZgBAKABAaoBB2d3cy13aXo&sclient=psy-ab#spf=1600266536310 Quote Link to comment Share on other sites More sharing options...
IsaMorphius Posted May 29 Share Posted May 29 (edited) What is the capacity of the battery that you use? I want to make something like this for my house, and I can't decide on the battery's capacity. I got some really colorful smart LED lights from https://www.vont.com/product/smart-strip-lights-led-strip-lights/ and need to install them somewhere inside the house. I want to use a battery to connect them to electricity because it would be too difficult to look for a socket nearby or connect the LEDs to the house's electrical system. So, I need a battery that I will not have to recharge too often, and that will be able to provide the LED with electricity every day. Edited May 31 by IsaMorphius Quote Link to comment Share on other sites More sharing options...
