Andre Kruger Posted September 15, 2020 Share Posted September 15, 2020 Hello everyone, can i use the Axpert King remote display firmware 02.49 alongside the Axpert King main firmware 71.93? thank you in advance Andre Quote Link to comment Share on other sites More sharing options...
Plaashaas Posted September 16, 2020 Share Posted September 16, 2020 9 hours ago, Andre Kruger said: Hello everyone, can i use the Axpert King remote display firmware 02.49 alongside the Axpert King main firmware 71.93? Yes you must. Upgrade the MCU first then DSP. Good luck with this. It can be frustrating for some. Quote Link to comment Share on other sites More sharing options...
Andre Kruger Posted September 16, 2020 Author Share Posted September 16, 2020 1 hour ago, Plaashaas said: Yes you must. Upgrade the MCU first then DSP. Good luck with this. It can be frustrating for some. Thanks Plaashaas - it was quite frustrating, cant seem to get the Bluetooth working, so i am hoping this update will work in getting it to work Quote Link to comment Share on other sites More sharing options...
Plaashaas Posted September 16, 2020 Share Posted September 16, 2020 2 hours ago, Andre Kruger said: Thanks Plaashaas - it was quite frustrating, cant seem to get the Bluetooth working, so i am hoping this update will work in getting it to work What was the issue with the Bluetooth? Are you using an iPhone? Quote Link to comment Share on other sites More sharing options...
Andre Kruger Posted September 16, 2020 Author Share Posted September 16, 2020 the bluetooth detects the device and it is able to pair with it, but within the watchpower app it does not detect the inverter i am using a Galaxy S9 on android 10 Quote Link to comment Share on other sites More sharing options...
Andre Kruger Posted September 16, 2020 Author Share Posted September 16, 2020 5 hours ago, Plaashaas said: Yes you must. Upgrade the MCU first then DSP. Good luck with this. It can be frustrating for some. i updated the MCU first as you said, and that went through succesfully, but the file i downloaded does not contain the file to update the DSP - any idea where i can find the dps.hex file? The inverter is now on 71.93 and the remote module MCU is done, i just need the file to update the DSP Quote Link to comment Share on other sites More sharing options...
Coulomb Posted September 16, 2020 Share Posted September 16, 2020 13 minutes ago, Andre Kruger said: The inverter is now on 71.93 and the remote module MCU is done, i just need the file to update the DSP If you have U1 71.93 and U2 02.49, then you are done. The same reflash tool (it seems) can be used for the MCU or the DSP. You would normally only ever press one or the other button. 71.93 is the DSP firmware in the inverter. Quote Link to comment Share on other sites More sharing options...
Andre Kruger Posted September 16, 2020 Author Share Posted September 16, 2020 Just now, Coulomb said: If you have U1 71.93 and U2 02.49, then you are done. The same reflash tool (it seems) can be used for the MCU or the DSP. You would normally only ever press one or the other button. 71.93 is the DSP firmware in the inverter. Hi Coulomb - thank you for the reply - after the update i see that the panel is now "dead", the is off but i can still access it via my serial cable - must i not perhaps do the DSP part as well to complete the upgrade? i cant see if the MCU upgrade was successful (i assume it was?) Quote Link to comment Share on other sites More sharing options...
Bloubul7 Posted September 16, 2020 Share Posted September 16, 2020 10 minutes ago, Andre Kruger said: Hi Coulomb - thank you for the reply - after the update i see that the panel is now "dead", the is off but i can still access it via my serial cable - must i not perhaps do the DSP part as well to complete the upgrade? i cant see if the MCU upgrade was successful (i assume it was?) If the display remains dead after the update has been completed then re-run the update. The display should power up once the update has been succesfully completed Quote Link to comment Share on other sites More sharing options...
Andre Kruger Posted September 16, 2020 Author Share Posted September 16, 2020 35 minutes ago, Bloubul7 said: If the display remains dead after the update has been completed then re-run the update. The display should power up once the update has been succesfully completed oddly enough, i reverted back to 02.40 and the panel came back online, it appears that with 02.49 it just stays "dead" Quote Link to comment Share on other sites More sharing options...
Bloubul7 Posted September 16, 2020 Share Posted September 16, 2020 Just try again, other users had the same issue. Reloading 02.49 resolved the issue Coulomb 1 Quote Link to comment Share on other sites More sharing options...
Coulomb Posted September 16, 2020 Share Posted September 16, 2020 1 hour ago, Bloubul7 said: after the update i see that the panel is now "dead", the is off but i can still access it via my serial cable That's interesting. It seems that the display firmware doesn't have to be running for serial commands to "pass through" to the DSP in the inverter, and the responses back again. I didn't expect that. 1 hour ago, Bloubul7 said: i cant see if the MCU upgrade was successful (i assume it was?) With the display dead, the MCU update has not worked, as others have mentioned. As @Bloubul7 suggests, repeat the 02.49 update until the display is working. Quote Link to comment Share on other sites More sharing options...
Andre Kruger Posted September 16, 2020 Author Share Posted September 16, 2020 3 hours ago, Coulomb said: That's interesting. It seems that the display firmware doesn't have to be running for serial commands to "pass through" to the DSP in the inverter, and the responses back again. I didn't expect that. With the display dead, the MCU update has not worked, as others have mentioned. As @Bloubul7 suggests, repeat the 02.49 update until the display is working. Gentlemen, i thank you for your advice, after trying the firmware update four times, the panel finally came back online and it is working as it should, but not the Bluetooth... lol Thanking you kindly for all your input, i really learned a lot today Quote Link to comment Share on other sites More sharing options...
Plaashaas Posted September 17, 2020 Share Posted September 17, 2020 15 hours ago, Andre Kruger said: the panel finally came back online and it is working as it should, but not the Bluetooth... lol I am running 2.49 and 71.93 and no issues with the bluetooth. It must be something else. Are you trying to use the watchpower app? Quote Link to comment Share on other sites More sharing options...
Andre Kruger Posted September 17, 2020 Author Share Posted September 17, 2020 1 hour ago, Plaashaas said: I am running 2.49 and 71.93 and no issues with the Bluetooth. It must be something else. Are you trying to use the watchpower app? Hi Plaashaas yes, i downloaded the watchpower app, and from the phone, it detects the inverter and the pairing can be made, however it says that an app is required to manage the device, but from within the app nothing is detected Quote Link to comment Share on other sites More sharing options...
Plaashaas Posted September 17, 2020 Share Posted September 17, 2020 Did you ever pair it with another phone? I think I have read somewhere that it can only pair with one device. Quote Link to comment Share on other sites More sharing options...
Bloubul7 Posted September 17, 2020 Share Posted September 17, 2020 Try deleting the paired device. Do not pair the inverter, open the watchpower and select it within the app Quote Link to comment Share on other sites More sharing options...
Andre Kruger Posted September 17, 2020 Author Share Posted September 17, 2020 48 minutes ago, Bloubul7 said: Try deleting the paired device. Do not pair the inverter, open the watchpower and select it within the app Thanks Bloubul 7 - let me go do just that Quote Link to comment Share on other sites More sharing options...
Andre Kruger Posted September 17, 2020 Author Share Posted September 17, 2020 6 hours ago, Plaashaas said: Did you ever pair it with another phone? I think I have read somewhere that it can only pair with one device. Hi Plaashaas - no, i only used my phone, i would have tried another phone if i had one... lol Quote Link to comment Share on other sites More sharing options...
sajjadmalik Posted January 20 Share Posted January 20 pls any help me reflash tool for upgrade axpert king 3.2 inverex this is error 32 but i have reflash v71.97 it is 5.2 kw Quote Link to comment Share on other sites More sharing options...
Coulomb Posted January 22 Share Posted January 22 On 2022/01/21 at 1:45 AM, sajjadmalik said: pls any help me reflash tool for upgrade axpert king 3.2 inverex this is error 32 but i have reflash v71.97 it is 5.2 kw Axpert firmware version 71.97 is for 5000 W models only; not 5.2 kW, and not 3.2 kW. Though I suppose that there might be a special Inverex version of 71.97. Inverex seem to have a special arrangement with Voltronic, where they get a slightly different display and metal case, and the power ratings are slightly higher. I assume therefore that they require special firmware. What are the circumstances under which you are seeing warning code 32? Did you actually attempt to flash a 3.2 kW machine with firmware version 71.97 for Axpert Kings? Quote Link to comment Share on other sites More sharing options...
sajjadmalik Posted January 23 Share Posted January 23 thanks sir i try to version 71.97 then total spacification chang and i try other firmware then remove able display has gone what i do sir Quote Link to comment Share on other sites More sharing options...
sajjadmalik Posted January 23 Share Posted January 23 no i have axpert king 3.2kw reflash tool and removeable dsp reflash 3.2kw Quote Link to comment Share on other sites More sharing options...
Coulomb Posted January 23 Share Posted January 23 6 hours ago, sajjadmalik said: then remove able display has gone The removable display is the same for Axpert King and Axpert VM III, 5kW and 3kW models. I have no idea whether non-Inverex removable display firmware will work with an Inverex display however. If you have a known Inverex removable display firmware, then you can try to update the firmware even though it appears to be bricked (non responsive). You probably need the removable display working in order to reflash the main inverter firmware. Wait: are you saying that you never changed the removable display firmware? If so, can you reflash to the previous main inverter firmware? You may be able to flash bypassing the removable display, I've never tried it. WARNING! The pinout for the display to inverter RJ-45 port is NOT the same as the regular RS-232 port, so you'd need an adapter. I'm pretty sure I published the details somewhere. Quote Link to comment Share on other sites More sharing options...
