Guss Davey Posted September 28, 2020 Share Posted September 28, 2020 Hi Does anyone have a manual for this battery? Busy designing cabinet for vertical mount and need to get dimensions. (Alternative.... just wait for it to arrive) Quote Link to comment Share on other sites More sharing options...
Powerforum Store Posted September 28, 2020 Share Posted September 28, 2020 Hello Guss I sent you the Spec Sheet the dimensions for the battery is in there including its weight unfortunately the Spec Sheet is too Large to upload Regards Power Forum Store Quote Link to comment Share on other sites More sharing options...
Energy-Jason Posted November 5, 2020 Share Posted November 5, 2020 On 2020/09/28 at 11:30 AM, Guss Davey said: Hi Does anyone have a manual for this battery? Busy designing cabinet for vertical mount and need to get dimensions. (Alternative.... just wait for it to arrive) Hi Guss. Hope you well. I'm in the same boat. Would love a vertical wall mount for this beast. Very interested to see what you have come up with. Sincerely Jason Quote Link to comment Share on other sites More sharing options...
Guss Davey Posted November 16, 2020 Author Share Posted November 16, 2020 (edited) On 2020/11/05 at 10:33 PM, Energy said: Hi Guss. Hope you well. I'm in the same boat. Would love a vertical wall mount for this beast. Very interested to see what you have come up with. Sincerely Jason Hi Jason Just did something quick and dirty. 25x25x1.6 square aluminium tubing (dead cheap). Connect-it connectors to join everything together. Will later wrap the whole thing in a PVC cover (with enough ventilation) If your frame will have feet to the floor, the 25x25x1.6 alu sq tube is good. If its going to float off the ground, just with wall fastening, this structure is too lightweight. I would then (floating / no ground legs) rather go mild steel, 25 x 25 x 2, all welded and then also do not forget about the height of the wall fasteners head... like some bolt flanges somewhere. Edited November 16, 2020 by Guss Davey Yellow Measure 1 Quote Link to comment Share on other sites More sharing options...
Guss Davey Posted November 16, 2020 Author Share Posted November 16, 2020 Yellow Measure 1 Quote Link to comment Share on other sites More sharing options...
Energy-Jason Posted November 16, 2020 Share Posted November 16, 2020 Wow fantastic! Would you make me a single stand for one bull Battery. Please do charge me. Sincerely Jason Quote Link to comment Share on other sites More sharing options...
HeinDuPlessis Posted November 25, 2020 Share Posted November 25, 2020 I need the manual to understand how to properly install it! Does anyone have any information on it? i.e. How do I link two batteries with the data cable - each battery has 2xRS485 ports - do I connect them cross-over? or left to left or right to right? Does it matter? I would also love to know that I've got the dip switches set correctly. Thanks! Quote Link to comment Share on other sites More sharing options...
HeinDuPlessis Posted November 26, 2020 Share Posted November 26, 2020 It actually has 3 x RS485 ports each.. Quote Link to comment Share on other sites More sharing options...
branderplank Posted June 12, 2021 Share Posted June 12, 2021 Hi Guys Also in need of a manual If anyone can please help Thanks Quote Link to comment Share on other sites More sharing options...
Kilowatt Power Posted February 14, 2022 Share Posted February 14, 2022 There's a user manual for the BSL 6.4kWh LiFePO4 battery on the Victron Energy site. Quote Link to comment Share on other sites More sharing options...
