Posted October 5, 20204 yr Folks - the following information was received (as below) re the Axpert Mkii. This is not captured anywhere in the product documentation (unless I missed it somewhere) Vaughan “We already inbuilt the function to bridge output N-G when the inverter is running in inverter mode. Due to this reason, we also removed the function of Program#38. You could check the inverter output voltage between N-G when the inverter is running in inverter mode. It should be at 0Vac.”
