HeinDuPlessis Posted November 8, 2020 Share Posted November 8, 2020 Hi I've got a growatt inverter with pv panels and 4 x 200ah AGM batteries. I am now looking to add another system in parallel, using the growatt parallel feature. However, can the new system now have a lithium battery? Or does it also have to be agm? Thanks! Quote Link to comment Share on other sites More sharing options...
Barryv Posted November 9, 2020 Share Posted November 9, 2020 (edited) Hello I don't know what Growatt module you have but if you look here. Parallel setup with inverter needs to be connected to the same's batteries. You can change the batteries to new ones but not separated batteries. Edited November 9, 2020 by Barryv hoohloc and Coulomb 1 1 Quote Link to comment Share on other sites More sharing options...
