8kw Deye invertor with pylontech batteries
R Cerva
 Share
Hi.  Hope you all well.
I've just removed 3 x mecer 5kw invertors and replaced them with 2 x 8kw Deye invertors.  I want the invertors to work from solar and batteries if solar not enought.  But it still draw power from the grid even if battery show 100%.  Any help with which setting needs to set to what so it can work like this.
8 x Pylon US3000, 18 x 365W panels to each invertor.
In battery settings : Lithium Mode -  00  In manual it states that this is BMS protocol.  Please reference the document (Approved Battery)  Can't find this document
Any help please.
Hi.  Here are some photos.  All settings I think is correct.  As long as my ac supply is present it does not want to run of the batteries.  I want the system to run on solar during the day and charge the batteries.  At night it must run on batteries till SOC is 25%.  Now I have to switch off the ac grid supply to get it to run on the batteries.
Any suggestions please.
Thanks.
solar fotos.pdf
 Share
