Gerald_db Posted June 12, 2016 Share Posted June 12, 2016 I visited a lodge owned by a friend of mine and here are a few pictures of the installation. Its not mine therefore not posted under Member installations but thought some forum members may be interested. Quote Link to comment Share on other sites More sharing options...
Mark Posted June 12, 2016 Share Posted June 12, 2016 Very very nice... (drool)... Southern Africa PV Output Team...? Quote Link to comment Share on other sites More sharing options...
Mike Posted June 12, 2016 Share Posted June 12, 2016 wowza, i would love that Mark 1 Quote Link to comment Share on other sites More sharing options...
UniqueFRQ Posted June 22, 2016 Share Posted June 22, 2016 Can u post some system specification s? Sent from my QMobile A6 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Gerald_db Posted June 23, 2016 Author Share Posted June 23, 2016 Not mine and just had a quick look but batteries are 2 x 48 x 2volt. I don't have the knowledge to say more than what yhe pictures show. Is too small thou and is going to be upgraded. Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted June 23, 2016 Share Posted June 23, 2016 Tell you mate that salt will keep the weeds down - is cheaper than weed killer and has a cumulative effect. I cleared the area in front of the panels and have sprinkled salt which has quickly bound with the soil. The problem with ground mounted panels is the weeds grow quickly on the drip line. I have not noticed any corrosion but this is the Karoo. edmundp 1 Quote Link to comment Share on other sites More sharing options...
edmundp Posted June 23, 2016 Share Posted June 23, 2016 20 minutes ago, Chris Hobson said: Tell you mate that salt will keep the weeds down - is cheaper than weed killer and has a cumulative effect. I cleared the area in front of the panels and have sprinkled salt which has quickly bound with the soil. The problem with ground mounted panels is the weeds grow quickly on the drip line. I have not noticed any corrosion but this is the Karoo. Brilliant - I am going to try this on my paving as well! Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted June 23, 2016 Share Posted June 23, 2016 1 minute ago, edmundp said: Brilliant - I am going to try this on my paving as well! Go to the co-op and get coarse salt it is about R1/kg. If you use the missus's table salt it is going to be an expensive exercise! Ed make sure it cannot leach into the garden the missus will have you guts for garters. Quote Link to comment Share on other sites More sharing options...
edmundp Posted June 23, 2016 Share Posted June 23, 2016 Will do. It is normal face brick paving. Salt cannot do worse to the rest of the garden than the stuff I am forced to use currently. (Accidentally ruined an entire 4x4 rose garden once by overspray.....) ___ and Mark 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2016 Share Posted June 23, 2016 Salt ... going to try that. We use vinegar, the stronger the better, to spray weeds. Quote Link to comment Share on other sites More sharing options...
viper_za Posted June 23, 2016 Share Posted June 23, 2016 I remember when my dad paved a very large part they put a layer of coarse salt down before laying the paving. This is probably 15-20 years ago and I have never seen weeds on that section of paving. The paving section done before that one do have weeds every now and then. Quote Link to comment Share on other sites More sharing options...
___ Posted June 23, 2016 Share Posted June 23, 2016 6 hours ago, edmundp said: Salt cannot do worse to the rest of the garden than the stuff I am forced to use currently I'm non-PC in this regard. Glyphosate, aka Roundup. It's bad stuff, but the half-life isn't too bad. If I'm worried about overspray, I ues MCP instead (Banweed). You can use that even on gras. Clint 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2016 Share Posted June 23, 2016 I have made a move years ago to not use any Roundup, Banweed or any of that off the shelf goed. Their adverts are not up to spec, and the dangers are not worth it. Was only vinegar ... till now that I got the salt idea here for a more permanent problem solving. Wish I knew that when we put in the driveway paving bricks. Quote Link to comment Share on other sites More sharing options...
Clint Posted June 23, 2016 Share Posted June 23, 2016 We used Roundup for many years in the landscaping industry ,it breaks down after few days and no longer remains a problem. Just remember to apply it when the ground is dry. ___ 1 Quote Link to comment Share on other sites More sharing options...
edmundp Posted June 23, 2016 Share Posted June 23, 2016 Its roundup that killed my roses....😢 Sent from my SM-N900 using Tapatalk ___ 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2016 Share Posted June 23, 2016 Roundup has had some bad press: http://www.huffingtonpost.com/maria-rodale/4-strange-sources-of-roun_b_6621914.html EDIT: And Monsanto, yo, they are getting it from all sides. Quote Link to comment Share on other sites More sharing options...
edmundp Posted June 23, 2016 Share Posted June 23, 2016 Monsanto is the devil!!! Sent from my SM-N900 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2016 Share Posted June 23, 2016 Just now, edmundp said: Monsanto is the devil!!! Jip, gets worse: http://web.mit.edu/demoscience/Monsanto/about.html Quote Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2016 Share Posted June 23, 2016 And then potentially really bad: http://articles.mercola.com/sites/articles/archive/2013/06/09/monsanto-roundup-herbicide.aspx Quote Link to comment Share on other sites More sharing options...
___ Posted June 23, 2016 Share Posted June 23, 2016 Monsanto is the devil!!! Sent from my SM-N900 using Tapatalk Hence my comment about being non PC. You know, between Facebook, alligators, gorillas, Monsanto, immigrants, guns, smoking weed... it's getting hard not to be on the wrong side of popular opinion. Sent from my GT-I9195 using Tapatalk edmundp 1 Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted June 23, 2016 Share Posted June 23, 2016 Roundup ½life is a load of cr@p. My wife had a iris nursery and we did some spot treatments before we expanded into a new section and years later I could see which rhizomes came from areas treated with Roundup and which areas came from untreated areas. Conventional weedkillers are plant hormone based. They stimulate the plant and the plant grows too fast causing its demise. Roundup action is different it acts on an enzyme that then blocks proteins essential to plant growth. This enzyme is only present in plants and hence Roundup's classification of low risk to human health. I am not so sure. In spite of it binding very tightly to soil particles in the glyphosate was found in the majority of waterways, streams and ditches and surprisingly in 77% of rainfall samples. It has now been classified as a probable carcinogen. I still use it but very sparingly for one specific problem weed. Mark, ___ and edmundp 3 Quote Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2016 Share Posted June 23, 2016 4 hours ago, plonkster said: ... it's getting hard not to be on the wrong side of popular opinion. No it is not, you just have to chose. Let me explain: Facebook - be private or use FB = wrong side. Alligators - either you run or you are food = wrong side. Gorillas - either you run or you are going to face a challenge = wrong side. Monsanto - either you support them or you are = wrong side. Immigrants - go back and fix yours or stay and create more problems = wrong side. Guns - you have a gun or you don't and then you are in deep sh_t picking a argument with a person that has one = wrong side. Smoking weed - you do and be free or you don't and condemn them = wrong side. Weed is good for you, Monsanto will disagree. Quote Link to comment Share on other sites More sharing options...
___ Posted June 24, 2016 Share Posted June 24, 2016 I think the difference comes in whether you open your mouth about the choice, or you just shake your head in disbelief and mind your own business. I have way too much of a knee-jerk not to open my big trap. That's the damn problem. So the other day I laughed my head off when this meme came past explaining the perfect storm: What happens when a gorilla shoots an alligator with an AR-15 to save the refugee child who was unsupervised because his transgender parent was in the bathroom (of zer choice) smoking weed grown by monsanto? Well... then the internet goes silent as everyone tries to figure out on which side they are supposed to be! :-) edmundp and Janma 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted June 24, 2016 Share Posted June 24, 2016 You had me in stitches!!! I am on the gorilla side by the way, he has the gun and the short temper. Quote Link to comment Share on other sites More sharing options...
___ Posted June 24, 2016 Share Posted June 24, 2016 This discussion just reminded me of this song: Quote Link to comment Share on other sites More sharing options...
