MartinKoch Posted November 21, 2020 Share Posted November 21, 2020 One more question please, I have 12 x 340 watt panels linked to my 5KVA Voltronic / Schubart inverter, can more be added? I would like to add 3 more on the other side of the roof, during winter the current panels get direct sunlight right from the start, now in spring, summer with the sun trajectory I miss early sun, daylight with very little solar power generation. Would like optimal power generation. Quote Link to comment Share on other sites More sharing options...
Coulomb Posted November 22, 2020 Share Posted November 22, 2020 17 hours ago, MartinKoch said: can more be added? I would not recommend 3 more, unless you use a separate MPPT to connect them directly to the battery. It sounds like you're using 3S of probably 72-cell panels; this will eventually cause you grief (see my signature). Quote Link to comment Share on other sites More sharing options...
MartinKoch Posted November 22, 2020 Author Share Posted November 22, 2020 2 hours ago, Coulomb said: I would not recommend 3 more, unless you use a separate MPPT to connect them directly to the battery. It sounds like you're using 3S of probably 72-cell panels; this will eventually cause you grief (see my signature). Thank you, will stick to the current setup then Quote Link to comment Share on other sites More sharing options...
