Solar panels on a axpert VM 111 5k
Kieftus
 Share
Do you see any problems with this proposed installation of 1 string of 9 panels ( Canadian solar, hiku 410w module... Voc 47,6 v and Isc 11.06A) so total string has an Voc of 429 volts. This is to be connected to a RCT axpert  VM3 5kva with a max Voc of 500 v........ Or make a 5 panel and a 4 panel string. Thank you Keith
You can't parallel different-length strings of panels. Also, any parallel string of modern large panels is likely to exceed the 18A limit, which seems to be a very bad idea.
But one string of 9 panels should be fine.
 Share
