SavioThecnic Posted November 26, 2020 Share Posted November 26, 2020 EASUN POWER 5000W ISolar SMK 5KW "Clone Mppsolar PIP 5048MK" Hi I bought an inverterEASUN POWER 5000W ISolar SMK 5KWI believe it is a Mppsolar PIP 5048MK CloneBut how can I be sure?I would like to understand this so that I know what firmware I can updatein my inverter I would very much like to avoidwhich always loads those 2A from utilityThere are modifications and improvements for this inverterI would like to manage the SUB and SBU scabio by time now I'm trying to do it with SolPipLogI would also like to manage the On battery discharge limitwhich SolPipLog doesn't handle for now and it would be nicebeing able to do everything from FW inverter I read that the PIP-MAX versionhas these things would be nice if there would also be in the MK seriesbut maybe there are changes or fw that enable this you know? Quote Link to comment Share on other sites More sharing options...
Coulomb Posted November 27, 2020 Share Posted November 27, 2020 (edited) On 2020/11/26 at 7:36 PM, SavioThecnic said: EASUN POWER 5000W ISolar SMK 5KW "Clone Mppsolar PIP 5048MK" Hi I bought an inverterEASUN POWER 5000W ISolar SMK 5KWI believe it is a Mppsolar PIP 5048MK CloneBut how can I be sure? It's so hard. I just don't know. But take heart from this EASUn unit (NOT the same model as yours) which updated to patched Voltronic Firmware just fine. I think that makes it 95% likely that they are not clones. Before updating with sticker, after updating. If as I suspect they are associated with Must Power, it may depend on when it was made as to whether it's genuine or not. More recent models seem to be genuine. As to whether it's a King model or not, Kings have setting 10 (operation logic) that other models do not. It should look like the unit in this advertisement. Quote it would be nicebeing able to do everything from FW inverter I read that the PIP-MAX versionhas these things would be nice if there would also be in the MK seriesbut maybe there are changes or fw that enable this you know? No, I only just learned of the discharge limit setting yesterday. I don't know of any non-MAX firmware that has this feature. Even removable display version 02.60 does not have setting 41. Edit: Axpert MAXs have their own removable display firmware series, e.g. version 12.03, suggesting that the MAX removable display firmware is separate from the King/VM III display firmware (the King/VM III display firmware are combined into one binary image). Edited December 8, 2020 by Coulomb Quote Link to comment Share on other sites More sharing options...
SavioThecnic Posted December 7, 2020 Author Share Posted December 7, 2020 Thanks for now I remain in doubt I also believe it is a genuine verifying it all looks identical to the voltronic Only rebranded but I was hoping for some testing to be sure 100% before trying to load a firmware Quote Link to comment Share on other sites More sharing options...
