Kiranbhowan Posted November 29, 2020 Share Posted November 29, 2020 Please can anybody advice why the axpert inverter 5kw lcd screen does not come on , it a new installed inverter it connected to 4 x 200 ah agm batteries , when it is powered on the lcd screen is blank please advice Quote Link to comment Share on other sites More sharing options...
0 Coulomb Posted November 30, 2020 Share Posted November 30, 2020 11 hours ago, Kiranbhowan said: Please can anybody advice why the axpert inverter 5kw lcd screen does not come on , it a new installed inverter it connected to 4 x 200 ah agm batteries , when it is powered on the lcd screen is blank please advice There is a cable from the main board to the LC Display; that that is loose, come off, of forgot to be put back, that would cause a lack of LCD backlight. But you say it's a new inverter; correcting or even checking this could void the warranty. Do the LEDs come on with the brief "lamp test" at start-up? Any sound at all? The other possibility is a catastrophic hardware failure, e.g. damaged main power supply, 200 A fuse blown, etc. None of these are likely on a brand new install. Are you sure that 48 V+ is getting to the battery terminals? Could be a missing / faulty fuse, wiring, etc. Quote Link to comment Share on other sites More sharing options...
Question
Kiranbhowan
1 answer to this question
