Kilowatt Power Posted December 7, 2020 Share Posted December 7, 2020 Hi, I'm finding the description of GST18 inverter AC-in and AC-out terminal points in the Victron manual a bit confusing The manual states the following: AC Output: The terminal points are indicated clearly. From left to right: ‘N’ (neutral), earth, and ‘L1’ (phase). AC Input: The terminal points are indicated clearly. From left to right: ‘L1’ (phase), earth, and ‘N’ (neutral). To cut a long story short, which GST18 pin is "L1" and "N" for AC-in and AC-out respectively top to bottom? Quote Link to comment Share on other sites More sharing options...
acs Posted December 8, 2020 Share Posted December 8, 2020 Hi, Don't you have the GST18 connector? On mine the connections are labelled. See attached photo of the male output connector with the cap removed. Kilowatt Power 1 Quote Link to comment Share on other sites More sharing options...
