2x Axpert 6048 MS negative power from ICC after putting the second inverter on
desiji
 Share
Please can somebody help to send me the best settings from 2 Axpert inverters running firmware 72.30
after starting the 2 inverter i get error 60 and in the info log from ICC it sates negative power detected fron 2nd inverter
only the master Axpert has PV which is 4200KW of panels i am not even getting closs to 3000
please need help with the best settings or how to eradicate the fault
thanks
I assume you mean 2 x PIP-5048MS inverters, equivalent to Axpert MKS 5K-48.
Are you using parallel boards?
Both inverters are in PAL output mode (setting 28)?
3 hours ago, desiji said:
4200KW of panels i am not even getting close to 3000
I assume you mean 4200 W nominal of panels. How many cells per panel, or what is the Voc?
How many are you wiring in series?
See my signature for how I feel about 3S of 72-cell panels on inverter-chargers (like the PIP-5048MS) that have 145 V absolute maximum PV voltage.
Thanks coulomb, it was a typo, i meant 2x PIP 5048MS inverter i have 15x 280 3S5P 60 cells panels
 Share
