Kha2 Posted December 21, 2020 Share Posted December 21, 2020 Hey guys I have just installed a 5kW Sunsynk inverter with 6x 400w panels system at my house with 1xNarada 4.8Kwh lithium battery. I just need some expert forum clarity(second opinion) on the settings that were done on the inverter. My installer selected AGM V as a battery type on the inverters battery settings and not Lithium even though my battery is Narada Lithium battery. I have attached a picture of the battery setting on the inverter. We are having issues though where we are not able to get the BMS reading from the battery and the installer advised to say the Narada battery is a bit of a problem when communicating with Sunsynk inverters. As we had connected and the communication cable from the battery to the inverter in the beginning of the installation the inverter kept throwing errors, F56, which the installer believed was caused by the communication cable and the he ended up disconnecting the cable from both the inverter and battery. Has anyone experienced this issue, is there a solution, how do we resolve this issue. Thanks Quote Link to comment Share on other sites More sharing options...
YellowTapemeasure Posted December 22, 2020 Share Posted December 22, 2020 @Halcyon, do you have a similar setup to the OP? Quote Link to comment Share on other sites More sharing options...
Kha2 Posted December 24, 2020 Author Share Posted December 24, 2020 Thank you very much @Vassen Quote Link to comment Share on other sites More sharing options...
EugeneS Posted November 4, 2021 Share Posted November 4, 2021 On 2020/12/24 at 7:44 AM, Kha2 said: Thank you very much @Vassen Hi @Kha2, it seems as if your issue was resolved, but part of the topic thread has been lost - I assume the user that posted deleted it or his account. Can you recall how it was fixed and perhaps provide me with some assistance? Quote Link to comment Share on other sites More sharing options...
Kha2 Posted November 15, 2021 Author Share Posted November 15, 2021 On 2021/11/04 at 11:01 AM, EugeneS said: Hi @Kha2, it seems as if your issue was resolved, but part of the topic thread has been lost - I assume the user that posted deleted it or his account. Can you recall how it was fixed and perhaps provide me with some assistance? Hey @EugeneS, one of the members here just simply replied that Sunsynk and Narada's BMS don't communicate, meaning you wont see the BMS readings on your inveter but only the SoC. So the settings are uploaded where confirmed to be fine as they are a work around due to the non communication of Sunsynk and Narada batteries. But after a year everything is working well with the settings as they are. Just need to find a better kettle as it is the only enemy to the solar system for now due to its high power consumption. Apologies for responding so late and hope my response helps you. NB: I am not an Expert... EugeneS 1 Quote Link to comment Share on other sites More sharing options...
