Surge protectors
Tariq
 Share
22 minutes ago, Tariq said:
thanks @brianh, Rubican does stock them, what do most of you guys use, the 600 v or 1000 v
I use Citel DS240-130DC for surge protection on my PV Panels. This has a max DC operating voltage of 180V, but they have other voltages versions available.
I use Citel DS240S-230/G for surge protection on the AC connections to my inverter. This is rated at max operating voltage of 255Vac.
I purchased both of these from Rubicon just over two years ago.
Note: Ideally you want to choose a protector that is rated slightly above your maximum panel/string voltage, but not too high - otherwise it offers less effective protection.
[Edit] This protection is more than adequate for Cape Town, but may need a more robust solution for more lightning-prone areas of the country!
Edited by NigelL
 Share
