djza Posted January 14, 2021 Share Posted January 14, 2021 Hi - Since having installed Pylontech batteries, my inverter has gone dead twice (inverter shuts down, either without or shortly after cutting over to grid). I thought this was because the setting to switch to Grid was too low (48V) and I changed it to 49V. However, now it switches to grid frequently so often it will use grid power to recharge the batteries sooner (at 48V it usually lasted through the night if I had a good sunshine day and started the evening with fully loaded battery). I then changed the parameter back to 48V (param 12) but now it seems not to re-read it and still switches at 49V, so am using grid power unnecessarily. How do I reset the inverter or force it to re-read and start using the new parameter again? Other changes seem to be instantly effective, but this one is just ignored. Some advice would be appreciated? DJ Quote Link to comment Share on other sites More sharing options...
