I have a axpert 3kva inverter with 2x12V 120ah gel batteries in serie,i only supply power to TV,DSTV explorer and 2 x router = 179 watt in total,regardless if i power up a 5w led light alone or all the above,after 1 hour inverter shows error “4” which means low battery power,all the equipment including the batteries is brand new,any suggestions what the problem could be?I am positive that all settings are correct.(but you never now)help please!And yes the batteries are fully charged once i change over to inverter during load sheding,and after the inverter cut off i measured the voltage of the batteries = 21V which is correct and set to cut off,it seams that the batteries drain very fast.
Question
JAS1
1 answer to this question
