Iiceman Posted February 5, 2021 Posted February 5, 2021 Hi All Not sure if this post should be in Inverters or Batteries...none the less. Ive had a 5.5kw Hubble battery paired with my SunSynk 5.5 inverter Ive noticed that the battery charges to 100% and back down to 99% constantly and then back up to 100 again, every couple of minutes. Battery is a week old now, and its been doing this ever since ive purchased it. Im not running any "Timers". Is this behavior normal? Here are my settings.. Please advise... Quote
Tariq Posted February 5, 2021 Posted February 5, 2021 That is normal, you will see the battery charging/discharging small amounts all the time. Quote
Iiceman Posted February 5, 2021 Author Posted February 5, 2021 55 minutes ago, Tariq said: That is normal, you will see the battery charging/discharging small amounts all the time. Thanks Tariq, much appreciated.. Quote
