Ian
Ian Mackenzie
 Share
Hi Ian, it is very important to read the installation guide that came with your batteries. Please see page 6 of the attached document assuming that you have received info on how to connect the batteries to the inverter. the manual shows you how to connect the batteries together if you have more than one. You only need one comms cable from the battery stack to a network spliter/switch, then you will have three cables from the spliter/switch to each inverter
US3000-Product-Manual-18BQSV0801.pdf
Apologies for trying to assist bro, meant no offence. With the little information you provided on your initial post, one would easily assume you did not have documentation for the batteries because you said you have new info for Growatt. If you have the correct info you would have seen that Growatt does not use CAN to communicate with batteries. I'm glad you are getting help from China, again, meant no offense
 Share
