February 13, 20215 yr Greetings, I purchased a hager 4 pole change over switch. I need assistance on how to connect it. The top part of the switch has following markings "R" "G1" "S" "G2" "T" "G3" "N" and "GN". The bottom part has the followings markings "L1" "L2" AND "L3". Can I be assisted with the wiring diagram.
February 13, 20215 yr 54 minutes ago, Brani said: R,S,T and N - from Grid G1,G2,G3 and GN - from Generator L1,L2,L3 - to the Load it would help if you take some pictures or give the make of the change over switch Make is Hager, he mentioned that in the post 🤨
February 13, 20215 yr Google is your friend. http://africa.hager.com/nf/files/download/0/232125_1/0/XP1_SF463_6S5503D_WEB.PDF Edited February 13, 20215 yr by NigelL
February 13, 20215 yr You realise you’ve bought a 3 phase transfer switch.What do you need it for? Inside the box there are clear instructions. I’ve installed three Hager transfer switches now and it was easy. Edited February 13, 20215 yr by Johandup
