ATiONthe Posted February 13, 2021 Share Posted February 13, 2021 Hi There, Would appreciate any direction with regards to where I can get a CANBUS Cable to hook up the Hubble AM-2 to the Deye 5KW Hybrid Inverter? Thanks Quote Link to comment Share on other sites More sharing options...
Anonymous Posted February 14, 2021 Share Posted February 14, 2021 On 2021/02/13 at 12:40 PM, ATiONthe said: Hi There, Would appreciate any direction with regards to where I can get a CANBUS Cable to hook up the Hubble AM-2 to the Deye 5KW Hybrid Inverter? Thanks You should have received a cable with your inverter if not contact hubble directly they may be able to help Quote Link to comment Share on other sites More sharing options...
swazz99jhb Posted February 20, 2021 Share Posted February 20, 2021 Hi. I have the Sunsynk. Came with a RJ45 (568B) cable. Is that to be used between the Sunsynk and Am-2? Do I plug it in the CAN port? And then? Thanks Quote Link to comment Share on other sites More sharing options...
swazz99jhb Posted February 20, 2021 Share Posted February 20, 2021 (edited) Yes that was the cable. Go to battery setup , select lithium, select CAN. SAVE Go to LiBMS. Done Edited February 20, 2021 by swazz99jhb Spelling Quote Link to comment Share on other sites More sharing options...
Bluefronted Posted May 21, 2022 Share Posted May 21, 2022 Hi. Is the CAN Bus cable different to a normal Ethernet cable ? If it is what other cable can i use as my batteries are a bit far away from my Sunsynk to use the Red cable as provided. Quote Link to comment Share on other sites More sharing options...
swazz99jhb Posted December 2, 2022 Share Posted December 2, 2022 Hubble confirmed that an ethernet cable works for CAN between Sunsynk and Hubble, but they've found it causes interference and recommend a cable with only pins 2,4 & 5 being used. Quote Link to comment Share on other sites More sharing options...
HendrikBigChief Posted March 3, 2023 Share Posted March 3, 2023 One other thing to do it to set the AM-2 hubble battery to address 1. This is the master address that will talk with the deye inverter. Quote Link to comment Share on other sites More sharing options...
