Dazed and confused- Wiring and Neutral Issues
RyanBM
 Share
Hey Guys
So I need some assistance please.
This is my setup:
Axpert King 3,2kw Inverter
2x 200ah Gel batteries
3 Phase DB- where the following is applied-
- The inverter is powered from Phase 3
- Selected Lights and Plugs have been reconfigured to run off the inverter
- Physically they are not on the same Phase as the Inverter, yet they are all connected off the neutral bar from the inverter
Between the DB, Inverter and Batteries I have-
- change over switch (Eskom or Batteries)
- earth leakage
- over current breaker
My issues:
- the installation by a qualified electrician has exceeded 16 hours on site with a system partly functional
- initially after wiring up the Inverter and on testing the board kept tripping- this continued for around the 1st 6 hours
- the assumed culprits were back feeds, dead neurtrals combined/ shared neutrals etc.
- after the tripping issues were resolved by tracing and separating neutrals the system could run as intended
- the next issue is two separate circuits- one a plug circuit and the other a light circuit won't work off the inverter
- both circuits show 220v on the output side when Eskom is down and the inverter is active- yet they don't work
So any ideas?
I have spent the equivalent of 16hours on electrician costs with a system that does not meet my needs.
Any help would be appreciated.
Tx
 Share
