Deon Zeelie Posted March 7, 2021 Posted March 7, 2021 Hi, I need guidance or help with my RCT inverter. From 9h30 till late afternoon my Solar input is stuck on 4187 w when drawing more than 4500 w (pv V=300 I=13.9kW=4183) even drawing more power out of the inverter. Connected are 2 strings of 8x 365 w Canadians. Running on one string I get 2600w. I am using the Watchpower app. Could this be an inverter issue or app Quote
Coulomb Posted March 8, 2021 Posted March 8, 2021 On 2021/03/07 at 7:42 PM, Deon Zeelie said: From 9h30 till late afternoon my Solar input is stuck on 4187 w That's the rated power for the solar charge controller. 53.3V battery x 80A max = 4184W. It's working flat out. If you need more solar power, you'll have to add another MPPT that charges the battery directly. Quote
Deon Zeelie Posted March 8, 2021 Author Posted March 8, 2021 Thank you for the help, much appreciated Quote
