TheBiscuit87 Posted April 17, 2021 Share Posted April 17, 2021 Hi all, I am new to the whole solar thing. I have been searching for the 69 error and found a few topics informing you to update the firmware but I am nor sure how to find it. Secondly what exactly does the bypass on the picture mean and what would the best settings be for a OG5.48 kodak system with 12 385w panels and 3 pylontech 3000c batteries be? Quote Link to comment Share on other sites More sharing options...
Coulomb Posted April 18, 2021 Share Posted April 18, 2021 16 hours ago, TheBiscuit87 said: I have been searching for the 69 error The exclamation mark in a triangle symbol means it's a warning, not an error. It just means that the battery is full and cannot be charged any more. 16 hours ago, TheBiscuit87 said: what exactly does the bypass on the picture mean It means that the loads are being powered directly from the utility. Notice how the two AC voltages in your photo are exactly the same. It could be because you chose SOL output source priority (setting 01), and it's after sunset. Otherwise, check settings 12 and 13 (back to grid and back to battery settings, respectively). TheBiscuit87 1 Quote Link to comment Share on other sites More sharing options...
TheBiscuit87 Posted April 23, 2021 Author Share Posted April 23, 2021 Hi Thank you so much! Just a last question what would the best Kodak OG 5.48 settings be for 3 x Pylontec 3000c batteries should I want to start using a raspberry with ICC to check my usage etc? Quote Link to comment Share on other sites More sharing options...
