Kawaman Posted April 20, 2021 Share Posted April 20, 2021 Hi Everyone, Quick question, I have at present 12 255W Solar Panels a Mecer Inverter (ratio power 5000VA/4000W) DC input 48VDC 93A. I have 1 Revov Battery Pack 51.2V. Would it be safe to add a second Revov 51.2V Battery Pack? Your answers are greatly appreciated. Kawaman Quote Link to comment Share on other sites More sharing options...
Jazzy Posted April 20, 2021 Share Posted April 20, 2021 53 minutes ago, Kawaman said: Hi Everyone, Quick question, I have at present 12 255W Solar Panels a Mecer Inverter (ratio power 5000VA/4000W) DC input 48VDC 93A. I have 1 Revov Battery Pack 51.2V. Would it be safe to add a second Revov 51.2V Battery Pack? Your answers are greatly appreciated. Kawaman Yes you will, cos the revov batteries come with an external BMS, you will be able to add another battery. However you will be limited to 5000 as your inverter will only go that far, as long as you don't go over 5000 with your inverter, you can have lots of power with two revov batteries. Quote Link to comment Share on other sites More sharing options...
Kawaman Posted April 20, 2021 Author Share Posted April 20, 2021 @Jazzy, Great News! I really needed to be sure. Thank You Quote Link to comment Share on other sites More sharing options...
Nicholas Posted May 11, 2021 Share Posted May 11, 2021 On 2021/04/20 at 8:04 AM, Jazzy said: Yes you will, cos the revov batteries come with an external BMS, you will be able to add another battery. However you will be limited to 5000 as your inverter will only go that far, as long as you don't go over 5000 with your inverter, you can have lots of power with two revov batteries. No, the Revov B100 (100Ah) does not have an external BMS but rather an internal BMS. Nonetheless, adding a 2nd 100Ah battery will most likely improve the system's performance, specifically with regards to storing excess solar energy when the inverter load-output is low and the solar generation is high. I'd recommend using a Victron BMV700 or 712 (Bluetooth) to measure and report Battery State-of-Charge accurately. Quote Link to comment Share on other sites More sharing options...
Kawaman Posted May 11, 2021 Author Share Posted May 11, 2021 Thank you both for the valued information, I will definitely look into the BMV712 (Bluetooth) will shop around, also great to know I'm able to add another Revov Battery. Quote Link to comment Share on other sites More sharing options...
Kawaman Posted May 11, 2021 Author Share Posted May 11, 2021 @Nicholas I was just thinking I have a very nice monitoring software called SolarAssistant of which I can monitor my battery performance, heat and charge rate. Would it not be an overkill using a Victron monitor as well? Here is the link to SolarAssistant https://solar-assistant.io/ Quote Link to comment Share on other sites More sharing options...
Nicholas Posted May 11, 2021 Share Posted May 11, 2021 1 minute ago, Kawaman said: @Nicholas I was just thinking I have a very nice monitoring software called SolarAssistant of which I can monitor my battery performance, heat and charge rate. Would it not be an overkill using a Victron monitor as well? Here is the link to SolarAssistant https://solar-assistant.io/ The Axpert Inverter has a very low accuracy with regards to DC voltage measurement and SOC (State-of-charge) calculation/estimation. You will want to integrate the Victron BMV 700/712 with Solar Assistant. You'll need to find out from the software developer whether they support the Victron BMV range of battery monitors. This should then replace the information that the inverter is presenting on behalf of the battery and replace it with the more accurate information calculated by the Victron BMV equipment. Quote Link to comment Share on other sites More sharing options...
Kawaman Posted May 11, 2021 Author Share Posted May 11, 2021 @Nicholas OK, you make perfect sense and thank you for replying so promptly, I will chat with the developer and get back to you (forum) as this will help others who have the same inverters. Quote Link to comment Share on other sites More sharing options...
Shadders Posted May 11, 2021 Share Posted May 11, 2021 1 hour ago, Nicholas said: The Axpert Inverter has a very low accuracy with regards to DC voltage measurement and SOC (State-of-charge) calculation/estimation Solar Assistant natively connects and communicates with the Revov B100 so it is reading from the battery and not the Axpert for SOC etc so this doesn't really matter. There is a setting for V.E. direct on Solar Assistant so I think it does support the BMV700/712 ? Quote Link to comment Share on other sites More sharing options...
Nicholas Posted May 11, 2021 Share Posted May 11, 2021 2 minutes ago, Shadders said: Solar Assistant natively connects and communicates with the Revov B100 so it is reading from the battery and not the Axpert for SOC etc so this doesn't really matter. There is a setting for V.E. direct on Solar Assistant so I think it does support the BMV700/712 ? I just saw on the Solar Assistant website that they have a cable that allows for direct communication with the Revov Life and 2nd Life batteries. That's great. @Kawaman is that how your system is setup? With a communication cable connected directly to the Revov B100? Quote Link to comment Share on other sites More sharing options...
Kawaman Posted May 11, 2021 Author Share Posted May 11, 2021 @Nicholas yes Sir. That is how I'm connected. Quote Link to comment Share on other sites More sharing options...
SolarAssistant Posted May 18, 2021 Share Posted May 18, 2021 On 2021/05/11 at 12:48 PM, Nicholas said: You will want to integrate the Victron BMV 700/712 with Solar Assistant. You'll need to find out from the software developer whether they support the Victron BMV range of battery monitors. Example system where a Victron SmartShunt is connected via VE.Direct cable: Very similar if you use the Victron BMV via VE.Direct cable: On 2021/05/11 at 2:29 PM, Nicholas said: I just saw on the Solar Assistant website that they have a cable that allows for direct communication with the Revov Life and 2nd Life batteries. That's great. Since SolarAssistant can read Revov directly, you don't need Victron shunts as others noted in this topic. This is what a direct connection to Revov looks like: If your inverter can't read your BMS directly, then you can use one of the connections above to switch inverter between modes as described below: https://solar-assistant.io/help/power-management/axpert We are currently working on adding RS485 support for Revov, which will be ready in the next week or two. At that point we will most likely stop selling RS232 cables for Revov and start selling it's RS485 cable. Some Revov batteries doesn't have an RS232 port. The software will keep on supporting both options. Quote Link to comment Share on other sites More sharing options...
alkafak Posted June 5, 2021 Share Posted June 5, 2021 Hi Sollar Assistant, could you please show cable configuration if i want to direct connection from your device to battery BMS, like a revov battery or something like pylon i want to make it for my battery pack Huawei ESM48100B3 Thank you Alkafak Quote Link to comment Share on other sites More sharing options...
