VernonR Posted May 11, 2021 Share Posted May 11, 2021 I have an AfriSolar inverter (I think it is a rebranded Axpert inverter). I'm just using it for backup power for a borehole pump. No PV installed, only batteries. The issue I'm having is that the Eskom supply voltage fluctuates between 242V and 248V, but the borehole pump can only support up to 240V (according to Franklin). I have had to replace 2 pumps in 7 months now as they burnt out, and according to Franklin it was due to too high voltage. Eskom also says they won't reduce it as other users will complain. I want the inverter to reduce the output Voltage to 230V even when grid is present, so for example 242V in, 230V out. Currently when there is grid power it just goes into bypass mode and the output Voltage is the same as the input. When no grid is present then the output is 230V. Quote Link to comment Share on other sites More sharing options...
Coulomb Posted May 12, 2021 Share Posted May 12, 2021 21 hours ago, VernonR said: I want the inverter to reduce the output Voltage to 230V even when grid is present, so for example 242V in, 230V out. Currently when there is grid power it just goes into bypass mode and the output Voltage is the same as the input. If it's a rebranded King, then it would do exactly what you want (unless the inverter becomes overloaded). But all Axperts will output 230 V (or even 220 V with a setting) when in battery mode, as you've noted when the AC-in is not present. It sounds like you are using the default UTI output source priority mode. If you switch to SBU mode, it will stay in battery mode even when AC-in is present, unless the battery voltage drops very low. It sounds like that might be tolerable, or at least much better, for your pump. If you want to avoid more than 230 V at the output at any time, then you'll need a double conversion model, such as an Axpert King. Afrisolar don't seem to carry that model. The King will require a battery, and may require the solar panels to be re-configured. Quote Link to comment Share on other sites More sharing options...
VernonR Posted May 12, 2021 Author Share Posted May 12, 2021 Thanks Coulomb. This looks like exactly what I wanted. I have changed the setting to SBU. Right now I have 246V in and 230V out. Quote Link to comment Share on other sites More sharing options...
