jhay Posted May 21, 2021 Share Posted May 21, 2021 Hi, Does anybody know what the serial commands are for querying and setting the "feeding grid power calibration" on the infini 3KW+ inverter? Quote Link to comment Share on other sites More sharing options...
jhay Posted May 30, 2021 Author Share Posted May 30, 2021 To answer myself, I changed my setup so I could run SolarPower and and snoop the serial port. To query, the command is QEBGP. The reply looks like this: QEBGP (+000 00 To set it, the command is ABGP+000, where the value is in Watt and it and it accepts positive and negative numbers. On my inverter, it seems as if all settings below +100 have no effect, so it was not useful to me to try and reduce the inverter's normal +-100Watt usage from the grid. At the end I played with a small bit of grid tie, 100Watt (using GPMP00100) seems to do it and the new Tshwane post paid meter, a HEXING HXE12-DL still seems happy. Quote Link to comment Share on other sites More sharing options...
