Moallam Posted May 21, 2021 Share Posted May 21, 2021 Hi I have Inverter Axpert_MKSII-5KVA. When the utility is connected, the utility indicator flashes repeatedly without switching to line mode or charging batteries. utility parameters is : 220 V 48.5 Hz inverter settings is : 01 : UTL 02 : 60 A 03 : APL 05 : FLD 11 : 30 A 16 : SNU all other settings as default. help me please. Quote Link to comment Share on other sites More sharing options...
Coulomb Posted May 22, 2021 Share Posted May 22, 2021 On 2021/05/21 at 10:04 PM, Moallam said: utility parameters is : 220 V 48.5 Hz If you mean that your utility has those readings, then I suspect that the low frequency is the problem. Is this actual grid power, or a generator? Quote Link to comment Share on other sites More sharing options...
Moallam Posted May 22, 2021 Author Share Posted May 22, 2021 (edited) 7 hours ago, Coulomb said: If you mean that your utility has those readings, then I suspect that the low frequency is the problem. Is this actual grid power, or a generator? @Coulomb This is generator. What is rang of frequency for Axpert MKSII 5KVA inverter? Edited May 22, 2021 by Moallam Quote Link to comment Share on other sites More sharing options...
Coulomb Posted May 23, 2021 Share Posted May 23, 2021 4 hours ago, Moallam said: This is generator. What is range of frequency for Axpert MKSII 5KVA inverter? I was a little pressed for time yesterday. I just looked it up: it should work down to 40 Hz, and come back on at 42 Hz. So more likely it is the frequency stability that is the problem. See FAQ #7 for a possible work-around. Quote Link to comment Share on other sites More sharing options...
