Jaco De Jongh Posted September 16, 2016 Share Posted September 16, 2016 Hi, i did mention this plan in some other post , but at that stage is was only a plan with some spares ordered. I know this will not work for everybody, but in my situation it will. I do have spare PV capacity 95% of the day, Before this plan, I ran my geyser on a timer from 2 to 4 every afternoon. That was sufficient for our demand and even left enough hot water for a morning shower. I tested the geyser and saw that it only switched on for 1 to 1and half hours a day, so I decided on the following solution. I had a company build me a 1 KW element. Had another company modify a spare plate for my current geyser to fit the1KW element (company number 2 messed their part up completely and left the plate in a perfectly useless condition. So i collected another plate from the scrapyard and modified it myself. Further more I increase the allowed running time to about 5 hours on the timer to allow sufficient heating. Spares used: 1 x Custom build 1Kw element = R360 1 x Scrap plate = R15 1 x Thermostat = Recovered from existing Geyser. Modification was done as follows. Original plate. Scrap Plate: As you could see, there is a difference in the type of element, as well as the holes in the 2 different plates. I did not want to ask someone to weld/braze a 1.25 inch nut to a plate again as that way of doing it did not work. (i am sure it can, but the guy I asked, returned the plate in a different shape than the one he received from me) so for my second attempt I went for a plate with a nut to fit the element. Last mention plate comes standard with 8 Holes and the original comes with 6 holes. the diameter of the plates were the same and 2 holes (Marked with a red line) matched perfectly. So i bolted the two plates together and used the 4 open holes as pilot holes to drill new holes in the 8 hole plate. That left me with cleaning up the plate a little and screw in the ! kw element. You can see the 8 hole plate now has a few holes more. The element that I bought included. Almost ready to go in, only saw this picture is blurry after the element was installed in the geyser. The newly drilled holes fitted perfectly, I ran the geyser for some time from the battery and it did well, takes about 26 Amps from my 48V bank. When the sun comes out in the morning Will see how the PV handles the element, but I can not foresee any problems. My current system should handle it with ease. And if all goes well, there goes my last 3 to 4 units I still had to buy from the council on daily basis. francois and viper_za 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 16, 2016 Share Posted September 16, 2016 Awesome Jaco. Well done. Excellent idee . I must agree it will work Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
___ Posted September 17, 2016 Share Posted September 17, 2016 Those bolts are stainless steel or plain galvanized? I'm not sure if plain would be a problem, I just saw what happens if you use plain bolts on a vented battery bank. Granted, much more corrosive environment, but now I tend to think twice about what I use :-) Quote Link to comment Share on other sites More sharing options...
Jaco De Jongh Posted September 17, 2016 Author Share Posted September 17, 2016 Hi @plonkster, those bolts were just used to keep the 2 plates together so that I could drill the new holes. I used the 6 hole as a template. Bolts in the geyser is stainless. ___ 1 Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted September 17, 2016 Share Posted September 17, 2016 My solution was a twin port plate also for Kwikot geyser and 2x 1500W elements which are reasonably easy to source. Addition: When the photo was taken I had a 1kW and a 1.5kW elements now we have two 1.5kW elements. Fritz 1 Quote Link to comment Share on other sites More sharing options...
KLEVA Posted September 21, 2016 Share Posted September 21, 2016 My plumbing "mechanic" recently had to replace my element in the 150l Kwikhot (a 2kW originally) due to an earth short... normal for a 10 year old geyser, so no issue there... But, he got a "good" deal on a 4kW element which "was great for solar installations"... Ummmm, my geyser is connected to a single Axpert!!! So although geyser element only used in exceptionally bad weather days, turn it on and the Axpert shits itself! I like the new element, because the water heats up faster than hell, but the rewiring exercise (to connect to municipal power only) and cost was huge... could've bought more water heating panels/tubes for that and negated the electrical connection completely! Quote Link to comment Share on other sites More sharing options...
Jaco De Jongh Posted October 27, 2016 Author Share Posted October 27, 2016 This geyser is a great source of confusion. Before I made the modification, I use to monitor it by watching usage on the prepaid meter, With a 3 KW element it use to be one for 1 to 1 and a halve hours per day. (3 - 4.5Kwh) per day. I replaced that with the 1KW element and allowed it (by using a timer) to run from 10H15 to 15H00 every day. I started Using AICC this week and was keen to see how long the geyser really takes to heat up the 150litre geyser, and I was shocked by the results. Some other facts that might be taken into consideration: The 3 to 4.5kwh was in winter time. The geyser is exposed to direct sun this time of the year from 12H00 till about 16H00 It is a new geyser that was installed in February (Kwickhot 610 duel ) witch is rated for 2.25kw heat losses over a 24hour period. Used by, 1x baby in baby bath, two small girls taking separate bathes, Mom taking a shower directly after work and then again late night, me taking a shower at night with enough hot water left for a shower in the morning. No pre-heating of water No additional heating methods. Nice hot ambient temperatures most of the year. My confusion comes in with the actual kwh usage as recorded by AICC over 3 days. Aicc shows that it is indeed a 1kw element. Day 1 it ran from 10H15 to 12H30 (2.25Kwh) Day 2 it ran from 10H15 to 12H45 (2.5Kwh) Today it ran from 10H15 to 12H45 (2.5Kwh) Does anybody have an idea what can cause this low kwh consumption? Its only slightly bigger than the standing loss rating. Can it be that with our hotter climate in Phalaborwa, the standing losses is so greatly reduced that I actually just have to heat up the replaced water? Quote Link to comment Share on other sites More sharing options...
___ Posted October 27, 2016 Share Posted October 27, 2016 1 hour ago, Jaco de Jongh said: Can it be that with our hotter climate in Phalaborwa, the standing losses is so greatly reduced that I actually just have to heat up the replaced water? The measured standing loss is done at standard conditions as specified by SANS 151: Ambient is 20 Celsius and the geyser is heated to 65 Celsius. If you do the usual thing of setting it for only 55, and your ambient is above 20 much of the day, then the standing loss will be less. You can actually work out a formula for your geyser. Newton's law of cooling says it cools down at a rate proportional to the difference between the current temperature and ambient. This means (I cannot remember the calculus to derive this, so you'll just have to trust my memory) that the formula is of the form T = c*e^(kt), where T is the temperature, e = 2.7182 and t (lower case) is time in whatever unit works for you. c and k are constants you have to solve for. If you plug in t=0, then T = c. Since the starting temperature for the test is 65, that means c = 65. It takes 1.16Wh to heat one liter of water by one degree centigrade. If you also know the standing loss over 24 hours is 2.25kwh, you know this represents 2250/1.16/150 = 13 degrees centigrade, and 65 - 13 = 52. So you know T = 52 when t=24. So now you can solve for k. Jaco De Jongh 1 Quote Link to comment Share on other sites More sharing options...
DeepBass9 Posted October 28, 2016 Share Posted October 28, 2016 Ambient in the roof in Phalaborwa is probably more like 35 to 40 degrees. ___ 1 Quote Link to comment Share on other sites More sharing options...
AndewJ Posted October 28, 2016 Share Posted October 28, 2016 where do you get the 1Kw and 1.5Kw geyser elements? I have been looking for one all over but no one seems to stock them. Quote Link to comment Share on other sites More sharing options...
___ Posted October 28, 2016 Share Posted October 28, 2016 1 hour ago, AndewJ said: where do you get the 1Kw and 1.5Kw geyser elements? I have been looking for one all over but no one seems to stock them. Voltex makes a dual element. http://www.voltexlighting.co.za/download/voltex_0.pdf Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted October 29, 2016 Share Posted October 29, 2016 13 hours ago, AndewJ said: where do you get the 1Kw and 1.5Kw geyser elements? I have been looking for one all over but no one seems to stock them. My local electrical hardware shop has 1kW elements without a pocket. I got 1.5kW elements with a pocket from TecsaReco (branches Durbs, CT, Jhb, Pta and PE and Bloem + some other places). Quote Link to comment Share on other sites More sharing options...
AndewJ Posted October 31, 2016 Share Posted October 31, 2016 Thank you. Quote Link to comment Share on other sites More sharing options...
Fritz Posted October 31, 2016 Share Posted October 31, 2016 On 17/09/2016 at 10:41 AM, Chris Hobson said: My solution was a twin port plate also for Kwikot geyser and 2x 1500W elements which are reasonably easy to source. Addition: When the photo was taken I had a 1kW and a 1.5kW elements now we have two 1.5kW elements. why do you use dual elements? Quote Link to comment Share on other sites More sharing options...
___ Posted October 31, 2016 Share Posted October 31, 2016 1 hour ago, Fritz said: why do you use dual elements? I suspect it's because you want to use the surplus power to heat water, and you're more likely to have 1.5kw surplus than to have 3kw surplus. Even if you have an array big enough so that you do have 3kw surplus at some point in the day, you will have that peak for a much shorter time. Since water heats more or less linearly over time and you have all day... using a smaller element is the ticket. The second one you put on a time switch and connect it to the grid. If the water isn't hot enough by the time time timer switches on, it takes it the rest of the way on the second element (or both at the same time if you put it in late afternoon). Jatho and viper_za 2 Quote Link to comment Share on other sites More sharing options...
viper_za Posted October 31, 2016 Share Posted October 31, 2016 3 hours ago, Fritz said: why do you use dual elements? For Chris being off grid the bigger element would use the generator more efficiently (time/diesel) I think he can even run them at the same time then. Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted October 31, 2016 Share Posted October 31, 2016 3 hours ago, Fritz said: why do you use dual elements? 1 hour ago, plonkster said: I suspect it's because you want to use the surplus power to heat water, and you're more likely to have 1.5kw surplus than to have 3kw surplus. Even if you have an array big enough so that you do have 3kw surplus at some point in the day, you will have that peak for a much shorter time. Since water heats more or less linearly over time and you have all day... using a smaller element is the ticket. The second one you put on a time switch and connect it to the grid. If the water isn't hot enough by the time time timer switches on, it takes it the rest of the way on the second element (or both at the same time if you put it in late afternoon). Plonky has the gist of it. I have a 3 phase generator and two phases come into my home. One powers the inverter and all the inverter fed circuits. The other powers a few non-essential lights, occasionally a small pump and the 2nd element in the geyser. So during the day I power one element with excess solar energy and then in the evening when the gennie goes on I can power both using separate phases. I could have 2 or 2.5kW for the second one but the phases are better balanced with 1.5kW. Jaco De Jongh and ___ 2 Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted November 1, 2016 Share Posted November 1, 2016 On 10/27/2016 at 9:22 PM, Jaco de Jongh said: This geyser is a great source of confusion. Before I made the modification, I use to monitor it by watching usage on the prepaid meter, With a 3 KW element it use to be one for 1 to 1 and a halve hours per day. (3 - 4.5Kwh) per day. I replaced that with the 1KW element and allowed it (by using a timer) to run from 10H15 to 15H00 every day. I started Using AICC this week and was keen to see how long the geyser really takes to heat up the 150litre geyser, and I was shocked by the results. Some other facts that might be taken into consideration: The 3 to 4.5kwh was in winter time. The geyser is exposed to direct sun this time of the year from 12H00 till about 16H00 It is a new geyser that was installed in February (Kwickhot 610 duel ) witch is rated for 2.25kw heat losses over a 24hour period. Used by, 1x baby in baby bath, two small girls taking separate bathes, Mom taking a shower directly after work and then again late night, me taking a shower at night with enough hot water left for a shower in the morning. No pre-heating of water No additional heating methods. Nice hot ambient temperatures most of the year. My confusion comes in with the actual kwh usage as recorded by AICC over 3 days. Aicc shows that it is indeed a 1kw element. Day 1 it ran from 10H15 to 12H30 (2.25Kwh) Day 2 it ran from 10H15 to 12H45 (2.5Kwh) Today it ran from 10H15 to 12H45 (2.5Kwh) Does anybody have an idea what can cause this low kwh consumption? Its only slightly bigger than the standing loss rating. Can it be that with our hotter climate in Phalaborwa, the standing losses is so greatly reduced that I actually just have to heat up the replaced water? You could install a Geyserwise timer to measure the temperatures before, and after heatup. Or you could hookup the thermostat to a Raspberry Pi or Arduino and measure it that way as well. What will show whether the water entering the geyser is much hotter than you expected it to be. Quote Link to comment Share on other sites More sharing options...
Haggers Posted November 6, 2016 Share Posted November 6, 2016 What is the normal element size for 150 L geyser? Quote Link to comment Share on other sites More sharing options...
viper_za Posted November 6, 2016 Share Posted November 6, 2016 5 minutes ago, Haggers said: What is the normal element size for 150 L geyser? Mine used to have a 3kw element. Replaced this with a 1kw and been heating with my PV ibiza 1 Quote Link to comment Share on other sites More sharing options...
Haggers Posted November 6, 2016 Share Posted November 6, 2016 3 hours ago, viper_za said: Mine used to have a 3kw element. Replaced this with a 1kw and been heating with my PV Ok so the idea is to reduce the load on the solar panels and gradually heat water with spare capacity. Quote Link to comment Share on other sites More sharing options...
Gabriel_2018 Posted October 26, 2018 Share Posted October 26, 2018 On 2016/10/27 at 9:22 PM, Jaco de Jongh said: This geyser is a great source of confusion. Before I made the modification, I use to monitor it by watching usage on the prepaid meter, With a 3 KW element it use to be one for 1 to 1 and a halve hours per day. (3 - 4.5Kwh) per day. I replaced that with the 1KW element and allowed it (by using a timer) to run from 10H15 to 15H00 every day. I started Using AICC this week and was keen to see how long the geyser really takes to heat up the 150litre geyser, and I was shocked by the results. Some other facts that might be taken into consideration: The 3 to 4.5kwh was in winter time. The geyser is exposed to direct sun this time of the year from 12H00 till about 16H00 It is a new geyser that was installed in February (Kwickhot 610 duel ) witch is rated for 2.25kw heat losses over a 24hour period. Used by, 1x baby in baby bath, two small girls taking separate bathes, Mom taking a shower directly after work and then again late night, me taking a shower at night with enough hot water left for a shower in the morning. No pre-heating of water No additional heating methods. Nice hot ambient temperatures most of the year. My confusion comes in with the actual kwh usage as recorded by AICC over 3 days. Aicc shows that it is indeed a 1kw element. Day 1 it ran from 10H15 to 12H30 (2.25Kwh) Day 2 it ran from 10H15 to 12H45 (2.5Kwh) Today it ran from 10H15 to 12H45 (2.5Kwh) Does anybody have an idea what can cause this low kwh consumption? Its only slightly bigger than the standing loss rating. Can it be that with our hotter climate in Phalaborwa, the standing losses is so greatly reduced that I actually just have to heat up the replaced water? It dependes on the ambient temperature, isolation and water "in" temperature. Quote Link to comment Share on other sites More sharing options...
Gabriel_2018 Posted October 26, 2018 Share Posted October 26, 2018 Don´t you prefer to use DC resistors? Quote Link to comment Share on other sites More sharing options...
Gabriel_2018 Posted October 26, 2018 Share Posted October 26, 2018 Power doesn´t come from the inverter and is very easy to modulate power whith a Mosfet circuit. Quote Link to comment Share on other sites More sharing options...
d3nominat0r Posted January 2, 2019 Share Posted January 2, 2019 On 2016/11/06 at 12:37 PM, viper_za said: Mine used to have a 3kw element. Replaced this with a 1kw and been heating with my PV @viper_za, are you still running this configuration? If so, how long does it take to heat your water from cold? Considering this rather than going solar geyser. Quote Link to comment Share on other sites More sharing options...
