Recommended generator to use on victeon multiplus 2 5000 watt
Hi all
My system won't accept my current generator wich is a schults 5 kw unit , my installer says output on the generator is not clean ......i am looking at the 7.5 kw petrol generator Adendorf sells.
Has anyone used this generator on victron inverters ? The 7 kw husquavarna is also a option for me.
All advice will be greatly appreciated.
On 2021/06/09 at 5:52 PM, Brani said:
I use Addendorf generator on my Victron, but it also was not clean, had to change the settings on the inverter to accept it. maybe ask your installer to check those before buying another generator?
Do you have this generator?
