Leshen Posted June 8, 2021 Share Posted June 8, 2021 Did this battery backup solution for a client. 1 x Kodak inverter paired with a Hubble AM2. Nice thing about the Hubble is that you only need 1 x AM2 which can deliver 5kw which matches the Kodak 5kw inverter. wolfandy, Energy-Jason, YellowTapemeasure and 1 other 4 Quote Link to comment Share on other sites More sharing options...
wolfandy Posted June 9, 2021 Share Posted June 9, 2021 Looks neat, @Leshen I am also looking at putting in a pure battery backup solution in another place I own. I still have an old Axpert here that I want to use for that, but was not sure on what lithium battery to use. Maybe you can provide some advice please: The Hubble does not have any problems with not being regularly cycled? I understand that they Pylons give out an error message and hence are not the right battery for a pure UPS solution. But in your experience, the Hubble works for that? I understand that lithium's do not like to be at 100% SOC when being permanently connected to a charger. On my laptop, I can select how I mostly use it, and if I select that I mostly work while connected to AC, it keeps the battery level at 79% SOC to extend the lifetime. How do you manage something like this? Or do you keep the Hubble always at 100%? Thanks in advance Quote Link to comment Share on other sites More sharing options...
YellowTapemeasure Posted June 9, 2021 Share Posted June 9, 2021 (edited) 2 hours ago, wolfandy said: Looks neat, @Leshen I am also looking at putting in a pure battery backup solution in another place I own. I still have an old Axpert here that I want to use for that, but was not sure on what lithium battery to use. Maybe you can provide some advice please: The Hubble does not have any problems with not being regularly cycled? I understand that they Pylons give out an error message and hence are not the right battery for a pure UPS solution. But in your experience, the Hubble works for that? I understand that lithium's do not like to be at 100% SOC when being permanently connected to a charger. On my laptop, I can select how I mostly use it, and if I select that I mostly work while connected to AC, it keeps the battery level at 79% SOC to extend the lifetime. How do you manage something like this? Or do you keep the Hubble always at 100%? Thanks in advance Nice neat install as always @Leshen @wolfandy I do know that Hubble have engineered the BMS in the Hubble S-100 (Lead Acid replacement battery) to not charge to 100% fully, by charging individual cells no more that 3.2V. This appears to be due to the fact that they are typically used in applications where the equipment is expecting the characteristics of a LA battery, where it is not sufficiently sophisticated to determine accurate SoC, and in most cases, does not have the means to control it. I am not sure about the AM-2 though, although would this not be the function of the charger? Considering that AM-2s are typically deployed together with relatively sophisticated kit? If not, I am sure that regular cycling will mitigate longevity risks, I am just not sure of the frequency. Perhaps @HubbleLithium can weigh in, or perhaps you could log a ticket with their support line ? Edited June 9, 2021 by YellowTapemeasure wolfandy and 87 Dream 1 1 Quote Link to comment Share on other sites More sharing options...
