gav Posted July 6, 2021 Share Posted July 6, 2021 Hi, I want to size my array to try and get as close to maximum as possible. Can someone help to confirm my calculations and thinking are correct? I have the following specs on my inverter (Luxpower SNA5000WPV): Max. PV Array power: 6400W Start-up Voltage: 100Vdc+-10Vdc Max. PV Array Open Circuit Voltage: 480Vdc Max. PV Charging Current: 110A This inverter has two MPPT inputs which can be set up either as "S: two independent String inputs" or "P: same string input for 2 MPPTs". If I get 14 x 455W solar panels e.g. Ja solar (Voc 49.85), create two strings of 7 and set the inverter to P: same string input for 2 MPPTs (which I assume takes the strings in as parallel but not 100% sure and it could be other way round) I should get the following results: Per string - PV string power: 3185W PV string Voc: 348,95Voc PV string Amps: 10.92A Since the inverter takes these two strings in as parallel the end result should be: power: 6370W Voc: 348,95Voc (important not to exceed inverters max 480Vdc) Amps: 21.84A Does this seem feasible? Any comments are appreciated. Quote Link to comment Share on other sites More sharing options...
gav Posted July 7, 2021 Author Share Posted July 7, 2021 anyone? Quote Link to comment Share on other sites More sharing options...
Kalahari Meerkat Posted July 7, 2021 Share Posted July 7, 2021 41 minutes ago, gav said: anyone? I guess that includes me... yes, if Voc is, lets call it 50V/panel and 7 in series, your Voc at around 350V would be well within specs for the MPPT input of your inverter, in fact you could do 9 panels in series, 450V and that should be ok, with a few Volts to spare, maybe go for 8 in series times 2 seperate strings into your inverter, this keeps the current per string lower and thus the cabling sizes a bit more in check. But your setup should also be ok, as for On 2021/07/06 at 8:39 AM, gav said: Max. PV Charging Current: 110A this would be on the battery end and not on the MPPT input side... and as for On 2021/07/06 at 8:39 AM, gav said: PV string power: 3185W PV string Voc: 348,95Voc nope, you'd need to see Vmp in reality, bu that should be close to 3185W/10.92A (assuming that's Imp as in Amps at max power), then the end result should 7 panels worth of Voltage... thus 3185/10.92=291.667V and this divide by the 7 panels is 291.667/7=41.667V app. per panel at maximum power... gav 1 Quote Link to comment Share on other sites More sharing options...
