Sc00bs Posted July 7, 2021 Share Posted July 7, 2021 Hi Guys I have a Sunsynk 8kw Inverter, 24 x JA 455w panels in 2 strings of 2P6S format in an East/West configuration 24 x 455 = 10 920W Max DC Power according to the spec sheet I have is 10,400W. I doubt very much I will get over that due to my North/South Split. Maximum Voltage/Amperage according to the spec is 500V & 18A+18A which equates to 9kw per MPPT or 18kw in total. I was thinking of adding another 8 x 455w panels to my setup as I am within the MPPT's range which would take me to 14 560W which is WELL over the max DC input power. Any other suggestions? I was thinking of maybe using a Grid-Tie Inverter and just connecting up some North facing panels, I assume that there must be a limit to the max amount of power I can feed in through the grid-tie port, anyone know what it is? Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted July 7, 2021 Author Share Posted July 7, 2021 Or a micro-inverter would also work I suppose Quote Link to comment Share on other sites More sharing options...
Achmat Posted July 7, 2021 Share Posted July 7, 2021 I was also thinking of this. I think what will happen is that you will reach peak power of 10 500w earlier and it will last longer into the afternoon instead of just have one hour of peak pv production. It would be cheaper this way than adding a micro inverter on the aux but also a lot more wasteful during the middle of the day. Basically instead of having 1kw of production after sunrise, there will now be more panels taking your production to maybe 2kw. It would then plateau earlier in the morning until later in the afternoon. Quote Link to comment Share on other sites More sharing options...
Achmat Posted July 7, 2021 Share Posted July 7, 2021 Is told that the max micro inverter size is 5kw on the aux and 12kw on the grid port. Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted July 8, 2021 Author Share Posted July 8, 2021 Thanks Achmat Thinking that a Solis 3kw Grid-Tie would do the job very nicely. Quote Link to comment Share on other sites More sharing options...
