October 16, 20169 yr Hi all For sake of simplicity I'd like to just put firmware download links in one place. My contribution: CPU1 72.60 Firmware CPU2 4.10 Firmware The files are hosted on S3 and won't get removed. These are thanks to KnottyBuoy who posted them in two other threads
October 26, 20169 yr Author If you have future files to host, PM me, I'll add them to my S3 bucket and the first post with credits to you. Really the only benefits of using S3 is that the files won't get removed, no need for logins and lastly S3 is fast (like 5% of the internet hosts something on S3)
October 26, 20169 yr I rented a 5USD/month server at DigitalOcean to host my stuff. Also intend using it as a VPN for NetFlix at some point. Safer than using someone else's proxy. :-)
January 28, 20224 yr On 2016/10/17 at 12:46 AM, Gnome said: Hi all For sake of simplicity I'd like to just put firmware download links in one place. My contribution: CPU1 72.60 Firmware CPU2 4.10 Firmware The files are hosted on S3 and won't get removed. These are thanks to KnottyBuoy who posted them in two other threads Hi. I hope you can help. I got 2 axpert 5kva inverters in parallel. (Bought in 2017) Firmware 52 30. Recently the load between the inverters started to differ when it is in overide mode. So that one will overload and the other will be on 25%. I was told to do a firmware update but nobody wants to tell me what firmware to update it to. And where I can find it. Would you be able to point me in the right direction.
January 28, 20224 yr 14 minutes ago, Otto2 said: Recently the load between the inverters started to differ when it is in overide mode. So that one will overload and the other will be on 25%. I was told to do a firmware update That doesn't sound like a fault that a firmware update would fix. 15 minutes ago, Otto2 said: I got 2 axpert 5kva inverters in parallel. (Bought in 2017) Firmware 52 30. Those inverters must have been old stock back in 2017. They will be PF0.8 models; the latest factory firmware for those would be 73.00. There is fully patched firmware version 73.00e as well. You can find links to these and much more at the PIP-4048MS and PIP-5048MS inverters index. There will be no need to update the SCC firmware, especially if you opt for the patched firmware.
January 28, 20224 yr Thank you so much. Sorry about the similar question I asked later. Still new on this forum.
January 28, 20224 yr Lastly. If you say the load difference between the two inverters is not firmware related. What could it be. My load sharing cable are connect as per instruction manual. What else could be the problem.
January 29, 20224 yr 12 hours ago, Otto2 said: What else could be the problem. The output wiring, including the output breakers. Edit: or possibly something on the main board, between the inverter output and the output terminals. For example, relay contacts, quick connectors on the PCB, cables loose in AC-out terminals, and so on. When you have an imbalance, you might be able to find voltage drops across cables, breakers, etc. on the one that is providing the lower share of the load. Edited January 29, 20224 yr by Coulomb
January 31, 20224 yr On 2022/01/29 at 4:08 AM, Coulomb said: The output wiring, including the output breakers. Edit: or possibly something on the main board, between the inverter output and the output terminals. For example, relay contacts, quick connectors on the PCB, cables loose in AC-out terminals, and so on. When you have an imbalance, you might be able to find voltage drops across cables, breakers, etc. on the one that is providing the lower share of the load. Thank you very much Coulomb. I appreciate your guidance.
July 27, 20223 yr Hi. I managed to get my loads balanced etc. I tried to flash the inverters with the flashing tool to install the firmware update. Not sure what went wrong but the tool picked up com4 and opened it. It did fail to communicate after a few minutes and I eventually left it. Did I do something wrong or is there software I can use to do the firmware upgrade? I was told to use Watchpower but my inverters are not on Wifi. The suppliers in SA are not to helpfull and want me to take them off and send them in for the upgrade. With the load shedding, we get it will not be possible to take that route.
July 27, 20223 yr On 2022/01/31 at 9:13 AM, Otto2 said: Thank you very much Coulomb. I appreciate your guidance. On 2022/01/31 at 9:13 AM, Otto2 said: Thank you very much Coulomb. I appreciate your guidance. Posted 1 hour ago Hi. I managed to get my loads balanced etc. I tried to flash the inverters with the flashing tool to install the firmware update. Not sure what went wrong but the tool picked up com4 and opened it. It did fail to communicate after a few minutes and I eventually left it. Did I do something wrong or is there software I can use to do the firmware upgrade? I was told to use Watchpower but my inverters are not on Wifi. The suppliers in SA are not to helpfull and want me to take them off and send them in for the upgrade. With the load shedding, we get it will not be possible to take that route.
July 28, 20223 yr 15 hours ago, Otto2 said: Not sure what went wrong but the tool picked up com4 and opened it. It did fail to communicate after a few minutes and I eventually left it. The reflash tool just picks the first com port that appears to be available. You have to know what port your USB to RS-232 adapter is on, and change the selection to that port. See these firmware update instructions: https://forums.aeva.asn.au/viewtopic.php?p=87765#p87765
September 24, 20223 yr Does anyone have axpert max 7.2k firmware updates? Got the typical no comunications with pylontech bms. Best regards Fábio
September 24, 20223 yr 6 hours ago, Exiumind said: Does anyone have axpert max 7.2k firmware updates? You didn't say if you wanted display or main DSP firmware. If the former (the display handles 99% of the BMS comms), I found only the one below in the files section: It's from June 2021, so 15 months old as I type. I would think that most comms errors with Pylontechs are due to cable problems, rather than firmware.
September 25, 20223 yr We meet again Coulomb, hope everythings allright on your side. Well i assume the display module carries all major comms, but since i have no idea about how the software runs on these inverters i though id better ask the general question. As for the cables, i already tried every combo(using the recomended pinout) i could think of, plus the dealer sent a custom cable with only 2 wires crimped on one end, pin 3>8, pin 5>7, and a stock reversible cable as well. Also there is an issue with the soc reading, while the batteries are full led lit, the inverter says they are at a max of 53%, im assuming its the firmwares fault too. Right now at 2am soc is 21% at 49.8v no loads active. Toughts? Cheers
September 25, 20223 yr 1 hour ago, Exiumind said: Also there is an issue with the soc reading, while the batteries are full led lit, the inverter says they are at a max of 53%, im assuming its the firmwares fault too. Until the inverter talks to the battery BMS, it can only guess the SoC based on battery voltage, and with an LFP battery, that guess will be terrible. So that's not firmware. What display firmware are you running now?
September 25, 20223 yr 4 hours ago, Exiumind said: U2 112 14 Ah. Then 12.11 is too old for you anyway. Since then, I've seen 112.19 and 12.21. 12.21 definitely seems later than 112.19; I have no idea why it drops the leading "1". I've juust uploaded 12.21. I doubt that it will fix your problems, but at least it's fairly easy to eliminate the firmware as a factor.
September 25, 20223 yr Thank you Coulomb, i will try to backup the current firmware just in case before i upload the new one. Hope to come back with some good news Cheers
September 25, 20223 yr Well guess what, it all worked! Bms comms restored and therefore the soc is now showing as it should appaerently. It is now 11pm and the soc is 77% at 49.5v, discharging at 4A(~230w) just lighting. I must thank you once again for your support on this one. Still, i must confess i almost wet my pants when i saw the display going dark 😆 as i read somewhere it could happen if the upload got interrupted or something gone wrong 😅 Will monitor the system closely for the next few days and post if i find anything odd. Cheers! Edited September 25, 20223 yr by Exiumind Update
September 26, 20223 yr 16 hours ago, Exiumind said: i will try to backup the current firmware just in case before i upload the new one. I'd be interested to learn how you accomplish that. 💭
September 26, 20223 yr 50 minutes ago, Coulomb said: I'd be interested to learn how you accomplish that. 💭 Yeah, i after realized that tool has no option for that.. That would really be something else 😅
March 15, 20251 yr Hallo. I have a mecer 8kw inverter. Quite regularly (once a week) it shows error f55 and stops. Have to switch it completely off and on again. Is there newer firmware or something that perhaps will fix that? Its currently cpu1 on 72.01 and secondary cpu on 112.14. Not sure if firmware on these are available anywhere?
March 16, 20251 yr 11 hours ago, AlbertMecer said:Its currently cpu1 on 72.01That's quite old; about 3 years old now. Fault code 55 is "over DC voltage in the AC output", which does not sound like it might not be fixed by firmware. But it's free, so you may as well try it.The latest 72.xx firmware for Axpert Max E 8kW '28066 non-Twin is 72.08. But it does not have the "presumed good" MPPT logic. So you might like to try 72.75, which does have this logic (so low light PV production should be OK), and it even has the QDOP command for SoC% values for three settings (mainly for other readers). If you need the absolute best performance in low light conditions (cloud etc), then consider patched firmware version 272.66.11 hours ago, AlbertMecer said:Not sure if firmware on these are available anywhere?Not to toot my horn too much, but the best way is to post on this forum with your existing firmware version (as you have, thanks!), and hope that I see and respond to your post. I collect all the Axpert firmwares that I can find, and explore their internals to a limited degree. So I can figure out what is the latest downloadable firmware for a given model (series, type of display, power rating, chipset, whether Twin, Duplex or neither) with particular features (e.g. good MPPT logic), search for it, and post a link to it. Edited March 16, 20251 yr by Coulomb
