ccitaly Posted July 26, 2021 Share Posted July 26, 2021 Hi All, I nned some advise. I have a Growatt SPF5000ES and I also have 16 - 370Watt solar panels producing a total of 5,920 watts. The specs are as follows Pmax - 370W Vmp - 34.30 Imp - 10.79A Voc - 41.00 Isc - 11.39 I would like to connect the panels 8 in series and 2 in parallel but I see that on the Growatt max panel amperage is 18 amps. Would this be a problem if total amps is 22? Or should I just use 10 panels in series? I would like to use all 16 panels to produce as much as possible. All panels would be roof mounted at 35 degrees facing south. Quote Link to comment Share on other sites More sharing options...
