Cobus28 Posted August 28, 2021 Share Posted August 28, 2021 Good day I have a 8Kw SunSync Deye inverter and two 4.8Kw Hubble x100-48 battery connected in par. My problem is I can’t get my battery to communicate with my inverters though BMS, can anyone maybe help me. Quote Link to comment Share on other sites More sharing options...
Chetty Posted March 24, 2023 Share Posted March 24, 2023 @HubbleLithium I have the same problem. Quote Link to comment Share on other sites More sharing options...
zsde Posted March 24, 2023 Share Posted March 24, 2023 Follow the guide in this link and use a LAN cable with the correct pin connections. https://www.hubblelithium.co.za/sunsynk Nicholas Strachan 1 Quote Link to comment Share on other sites More sharing options...
HendrikBigChief Posted April 3, 2023 Share Posted April 3, 2023 If after following the guide it still does not work, cut the unused wires in your lan cable, they are causing interference that is blocking the signal. Quote Link to comment Share on other sites More sharing options...
Jacques69 Posted April 10, 2023 Share Posted April 10, 2023 Hi i made this cable but its still not working. Do i plug one end into the sunsynk 485 and the other ons the x100 485 A? Not sure thanx Quote Link to comment Share on other sites More sharing options...
HendrikBigChief Posted May 29, 2023 Share Posted May 29, 2023 (edited) On 2023/04/10 at 4:07 PM, Jacques69 said: Hi i made this cable but its still not working. Do i plug one end into the sunsynk 485 and the other ons the x100 485 A? Not sure thanx Is it still not working? If not, it is not the end of the world. I now run my hubble battery without comms, my deye inverter does a better job managing the battery SOC than the BMS on the battery itself as the Hubble BMS has knows issues calculating the correct SOC. Edited May 31, 2023 by HendrikBigChief Quote Link to comment Share on other sites More sharing options...
