September 16, 20214 yr Any suggestion on energy meter that can monitor incoming grid power and solar power been generated from two seperate inverter systems. System consist of the following, 48 volt systems. 4kw is fed from 15, 330 watt panels and store power in two 3.5kw Pylontech batteries. The other system is a 2kw system been fed from 6, 330 watt panels and store power in 4 AGM batteries. Any suggestion for a energy monitor equipment that can be added to existing system and can save info for at least 7 days. Info to be send via wifi to an app or to be download able via USB to an app.
