January 16, 20224 yr A 5 kva Luxpower inverter . I have 4 x lithuim battery s (48 v ) The box pole /studs type battery Vision 200 ah No coms port not pylon . The battery charging settings 3 ? What settings do you chose ? Lithuim without coms port ? what number is lithuim witout coms port ? If you chose lithuim 1 the inverter does not see the battery . Think there is about 20 different numbers under lithuim . Ended up setting it to Led acid With 54 v bulk (7) and 53.6 (8) triggel charge . Edited January 17, 20224 yr by Witbaas
