June 28, 20224 yr Hi all I've got about 30 staff in our business using this model of inverter. After a couple of years they are starting to fall over (constant loadshedding does not help!). What do you guys recommend as a good replacement battery (lead acid and alternatives?) https://ellies.co.za/product/720w-1200va-inverter-with-trolley-modified-sinewave/
February 21, 20233 yr On 2022/06/28 at 9:51 AM, RichardZA said: Hi Richard, Did you ever find out about replacement batteries? This stage 8 constant loadshedding has pushed my same model to not even last through the 2 hour stints. Jen Hi all I've got about 30 staff in our business using this model of inverter. After a couple of years they are starting to fall over (constant loadshedding does not help!). What do you guys recommend as a good replacement battery (lead acid and alternatives?) https://ellies.co.za/product/720w-1200va-inverter-with-trolley-modified-sinewave/
November 29, 20232 yr Has anyone replaced these gel batteries in the Ellies inverter to a Lithium battery of the same spec? Can this work?
