June 29, 20224 yr Hi All, My brain is just not wired to understand the various calcs. and numbers floating around. I currently have the following inverter from geewiz: https://www.geewiz.co.za/long-run-ups-inverter-battery/5373-2400va-mecer-inverter-2x-100ah-batteries-trolley-8-hour-battery-life-kit-1440w.html During load shedding this powers my PC + 2 screens, a TV and router for around 5 hours (depends if im gaming inbetween) With the recent load shedding at stage 6 this is not powerful enough and I would like advise on an upgrade that can take me from 5 hours to 12 hours + I prefer pre-made systems as I can assure you, if I have to wire something, it will explode. I have been looking at something like this: https://www.powerprovider.co.za/product/1kva-1-5kwh-lithium-compact-power-station-ups/ Will this 'power station' run for longer than 5 hours - how does it compare to what I have already? Would: https://www.geewiz.co.za/long-run-ups-inverter-battery/178349-2400va-mecer-inverter-2x-120ah-batteries-trolley-12-hour-battery-life-kit-1440w-with-hubble-lithium-battery.html be a better option - not sure what kwh battery is in the geewiz lithium option. Maybe a 2.5kwh battery option is better: https://www.powerprovider.co.za/product/energy-independence-3kva-2-5-kwh-compact-power-station/ Regards A little confused
