September 17, 20223 yr Hi all, what is your views on the Growatt SPF5000 ES inverters. Is it reliable? What would be your recommendations. Thanks apologies new to all this solar, backup power business. Thanks
September 17, 20223 yr I have two of them in parallel, running for just over a year now, I'm happy with them. I had a problem with one of them in the beginning, took it to the supplier (Elleyhill Power) repaired under guaranty while I waited. Excellent service. Just one thing that everyone has had some negative comments is the fact that they are a bit noisy. I will just recommend, if you decide to go with Growatt, get yours from Elleyhill Power in case you need assistance, they are excellent when it comes to customer service.
September 17, 20223 yr Author 1 minute ago, Antonio de Sa said: I have two of them in parallel, running for just over a year now, I'm happy with them. I had a problem with one of them in the beginning, took it to the supplier (Elleyhill Power) repaired under guaranty while I waited. Excellent service. Just one thing that everyone has had some negative comments is the fact that they are a bit noisy. I will just recommend, if you decide to go with Growatt, get yours from Elleyhill Power in case you need assistance, they are excellent when it comes to customer service. Thank you very much
