April 10, 20233 yr Hi, I found an older on grid solar inverter (new in box) and want to set it to use some how. However I got confused when looking at the spec's to decide what it can handle. Vmax pv 550v Vnom pv 370v Vmpp pv 150-500 Imax input pv 8A Vnom ac 230v Imax output ac 7.8A Freq 50Hz Pnom ac 1600W Max DC power 1700 W User manual states that max input current to MPP tracker is 15A (it has 1) But on the inverter casing the Imax input PV is 8Aas mentioned above. So my plan was to set it up with 4 Trisolar 425W Vector S panels (DE09R.08) However Maximum Power Current-IMPP (A) is rated at 10.08A and short Circuit Current-ISC is rated at 10.61A. So my questions are. What does the Imax 8A mean and how does this make sense in regards with 15A max current for the moon tracker input? And am I actually over the inverters limit with this suggested setup. I think I am and might have to drop the idea and go for lower W solar panels to keep under the 8A Imax pv input. Hope someone can help.
