Ecco Help!
Hi all!
So so new to solar community, I purchased this Inverter due to the price and apparently being able to connect up to 8 via a dongle. I have 4 200Ah Allgrand VRLA gel batteries connected in s/p with 2kw of panels.
So here is a conundrum for all the inverter specialists out there. This is my third post, hopefully someone will reply. I'm running this
This inverter has no battery selection type setting, no bulk setting in user mode, in fact there is only a user mode. Battery settings as follows.
1. Equalization. Which is a big no no for gel and according to Allgrand spec sheet.
2. Float 13.6 Allgrand spec
3. High voltage cut off.
4. Low voltage cut off.
So my question is, if there is no default setting for Gel or AGM, no bulk charging or absorption setting how is one supposed to charge any battery.
Either I'm dof or this is a piece of shite.
No response from numerous big companies selling this item.
Thanking you in advance.
