July 18, 20233 yr Good evening all, New member here and new to inverters and batteries. I am sure this question has been asked, if so I do apologize however I can certainly do with the assistance or advice. My question is what are the good and not so good choices when it comes to LPF batteries to be used with a hybrid inverter for home use. To give context I would like to make the investment into the solar energy movement for alternative energy supply to the home. To start with as phase one I am thinking of a 8kw hybrid inverter coupled to 2 x 5.12kwh LPF batteries, without solar panels initially. As pahse two when budget allows panels will be added. From what I have read and researched a safe bet considering both after sales service as well as bang for buck sunsynk and deye are good choices as far as inverters are concerned. However there does not seem to be similar clear consice advice on batteries as there is with inverters - or at least I have not found such. With each respective inverter mentioned, what would be the best suited LPF battery make and model to consider? Of importance to me with regards to the batteries are the below, - warranty (of battery and as well as inverter when combined with battery) - low failure rate - compatibility with said inverters - 1C rating - reliability Thanking you all in advanced Regards Richard
