August 1, 20233 yr Has anyone used this product? https://plentify.io/ Currently have a Geyserwise for the Solar Geyser but keep having to manually adjust the times when loadshedding changes and the scheduler is very basic. Think this might be another option. Edited August 1, 20233 yr by Everr Spelling
June 10Jun 10 Old post, but for what its worth I am using 2 of these units on a Parallel Geyser installation, secondary feeding primary, feeding the home. Works 100%, set and forget really.
June 10Jun 10 7 minutes ago, GandalfCoops said:Old post, but for what its worth I am using 2 of these units on a Parallel Geyser installation, secondary feeding primary, feeding the home. Works 100%, set and forget really.I assume you mean series?I am curious, so the element is in only 1 geyser and that one feeds another which doesnt have a supply? And you have hot water as long as there was enough generation to heat the first geyser that feeds the second one?
June 10Jun 10 Apologies yes, they are in Series with the cold water supply feeding the Secondary and the Secondary feeds the primary which ultimately feeds the home. I do have the plumbing to switch to user only the Primary or only the secondary but never do that.Both operate independently with 2 hotbots controlling the temps. The primary is heated first from schedules and/or excess solar and then if there is additional excess the secondary is heated. So essentially its 300l made up of 2x150l which allow me to not HAVE to heat the full 300, whatever I can get into the secondary is bonus and helps the primary out.Works really really well for my requirements.
