Cb1
Hi all, just starting out, I bought the following, but found out today not all inverters are compatible with lithium batteries, please advise if what I have will work before I open the boxes. I'll rather swop the inverter for another one than not be able to run the system correct.
Fivestar hybrid inveter GF-8048MBW
Felicity Lithium battery lpbf 48100
I hear that you could make it work but it would be preferable that the communication between battery and inverter be optimal for longer existenz. Thank you vey much.
