Complete Solar system | Canadian Solar 5 x 305 w | 3KVa Synapse Axpert Hybrid Inverter | 2 x 12 volt 100AH GEL batteries | R 15 000
Item: Complete Solar system | Canadian Solar 5 x 305 w | 3KVa Synapse Axpert Hybrid Inverter | Oliter 2 x 12 volt 100AH GEL batteries | All connectors & 25 meter 6mm single core wire & some trip switches
Age: 2 years
Price: R 15 000 onco
Payment Method Accepted: EFT
Proof of Purchase: Yes all invoices
Warranty: On Panels manufacturer
Packaging: None
Condition: Excellent
Reason: Emigrating
Shipping: If you can organize sure, but these are large panels and the batteries are heavy AF
Collection: Preferred
Link: https://www.canadiansolar.com/wp-co...anadian_Solar-Datasheet-KuPower_CS3K-P_EN.pdf
www.inverter-warehouse.co.za
Oliter 100Ah/12v Gel Battery
Oliter batteries are maintenance free and easy to use. Advanced technology research and development produce high-performance batteries.
www.inverter-warehouse.co.za www.inverter-warehouse.co.za
www.solarflaregreen.co.za
Synapse 3.0V+ 24V Off-Grid Inverter - Solar Flare Green Power Solution
Synapse 3.0V+ Off-Grid Inverter (Voltronic Axpert VM 3000-24). Pure sine wave solar inverter. Output power factor 1. High PV input voltage range. Inverter running without battery. Built-in 40A MPPT solar charger. Battery equalization function to optimize battery performance and extend life.
The system was put together to run everything in my house during the day and use municipal during the night (some things used timers to turn off at night), batteries were only used to balance the load to discharge as little as possible, they will have at least another 3 - 5 years of good performance left based on the spec sheets.
I used gas geysers and gas burners for cooking, you could use this system totally independent from the grid but you would need to add some more batteries dependent on usage load.
Edited by Georg2546
Photo update
On 2024/01/15 at 9:47 AM, Riaan36 said:
Are you willing to sell off just the solar panels?
If so price for them?
(Please check current market rates per Watt)
Hi Riaan, not yet. Will keep you posted.
