May 7, 20242 yr I have a question regarding the SSEG process for a specific requirement. I have a client that resides in a small business park. This park has only 1 ERF but there are multiple tenants. My client is one of the tenants wanting to install an inverter system and solar. The owner of the ERF is concerned that if we do the process for this client, they will not be able to update the application on the ERF should other clients also want to go the solar route at a later stage. So, my question is this: Are you able to update your application if you make changes after installation? Are you able to do multiple applications for one ERF if there are multiple tenants on the same premises each wanting their own system?
